07-24-2021, 09:34 PM | #1 |
40 Mercury Broken Grille tooth
Hey all you gurus
My 40 merc has a broken top grille tooth. I believe the grille is pot metal and is otherwise in good shape. Is 2 part epoxy worth a try? Other better ideas? Thank you
Craig 89, 69, 53, and 40 Mercs |
07-24-2021, 09:37 PM | #2 |
Re: 40 Mercury Broken Grille tooth
I would think so. JB weld might work
07-24-2021, 10:04 PM | #3 |
worth a try. I had to cut a small section out of my '60 ford stamped aluminum grill to get to the hood latch. Reinstalled it with clear 2 ton epoxy. It did discolor a bit but has lasted almost 4 yrs.
07-24-2021, 10:34 PM | #4 |
It is worth a try, but it did not work on my grill. It held until winter, I tried it again in the spring, but it did not last very long.
TomO |
07-25-2021, 07:51 AM | #5 |
If 2 part epoxy OR J B Weld don’t work, check out “Muggy Weld” on google/YouTube. Not sure IF anyone here can vouch for it?? There are
Some companies out there that can fix it!!! |
07-25-2021, 08:11 AM | #6 |
I think that if you could find someone experienced in this it would be better than trying to do it yourself (unless you are that skilled person). |
07-25-2021, 09:02 AM | #7 |
This guy answered my ad about pot metal repair over on the HAMB. Pot Metal Repair, [email protected] 707-621-5052 Said to text him? Is in CA.
