Old 06-24-2019, 06:08 PM   #1
bobsmanstuff
bobsmanstuff's Avatar
Default shutter
My 1930 pickup runs and idles real nice until I give it some r's, then it shutters. I was told it's possibly the pressure plate. What all is involved in replacing it with a new one? Thanks Bob
bobsmanstuff is offline   Reply With Quote
Old 06-24-2019, 06:39 PM   #2
Purdy Swoft
Purdy Swoft's Avatar
Default Re: shutter
It will be necessary to first remove the backend and transmission for access to remove the clutch .
Old 06-25-2019, 05:36 AM   #3
Patrick L.
Patrick L.'s Avatar
Default Re: shutter
You might try looking at the finger adjustment first. They can be adjusted thru the inspection cover.
Old 06-25-2019, 06:06 AM   #4
bobsmanstuff
Default Re: shutter
Thanks guys. I'll check it out.
Old 06-25-2019, 08:00 AM   #5
rocket1
Default Re: shutter
If it shutters or chatters when taking off it could be worn lining or broken hub spring in the disc.If it makes the noise when you are underway it might be the clutch slipping because it is worn out,I would check the clutch pedal shaft free play first and finger adjustment,while you are there lube the throwout brg.
rocket1 is offline   Reply With Quote
Thread Tools
Display Modes
