Old 04-16-2019, 04:20 PM   #1
SAJ
SAJ's Avatar
Default Bendix bolt retrieval
Trevor lost a bendix bolt on our South Island rally in Te Anau. I had read on Fordbarn varoius retrieval methods. All we had was an old vacuum cleaner and my syphon hose. It caught the bolt end-on so easily I could not believe it!
SAJ in NZ
SAJ is offline   Reply With Quote
Old 04-16-2019, 09:24 PM   #2
Mike Peters
Mike Peters's Avatar
Default Re: Bendix bolt retrieval
So you fed the siphon/vacuum hose through the starter opening and down into the flywheel housing to retrieve the bolt?
Mike Peters is offline   Reply With Quote
Old 04-16-2019, 10:12 PM   #3
whirnot
whirnot's Avatar
Trevor needs to buy lottery tickets
Bill Worden
1929 Roadster
1929 Briggs Town Sedan
1930 Closed Cab pickup
Smith Motor Compressor
1951 Ford F1
High Desert Model A's
whirnot is offline   Reply With Quote
Old 04-16-2019, 11:22 PM   #4
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
Hadn’t thought of doing it that way!
Old 04-16-2019, 11:44 PM   #5
w.michael
w.michael's Avatar
You carry a siphon hose?
W. Michael
w.michael is offline   Reply With Quote
Old 04-17-2019, 04:19 AM   #6
SAJ
SAJ's Avatar
Yes it is a "jiggle valve" siphon so I can get my spare petrol from the 2 gallon can into the tank without spilling or scratching my paint.
And yes we just fed it down through the hole where the starter goes and it picked it up immediately. We could not find a tab washer though. Maybe that is why the bolt came loose.
SAJ in NZ
Old 04-17-2019, 07:29 AM   #7
Joe K
Joe K's Avatar
You'll find the tab washer in a gob of grease attached to your starter pinion broken tooth where it got transferred by the flywheel ring gear.
Well, thats where I find my ANYTHING - or similar location/circumstance performed by equally happenstance occurrence.
There is a Murphy Corollary at work here somehow.
http://www.murphys-laws.com/murphy/murphy-laws.html
Joe K
Shudda kept the horse.
