07-15-2018, 06:50 AM | #1 |
Putting an 8BA in an "A"pickup
Do the narrow pulleys for the crank, and water pumps on a 53 flat head take up less space between the motor,and radiator than the wide pulleys. If so is it enough to make a difference?
Also the narrow pulley for the crank do not seem to be available as a new part Are the wide pulleys less likely to have slipping issues? Thank you in advance for any input you might have. Ken |
07-15-2018, 10:59 AM | #2 |
Re: Putting an 8BA in an "A"pickup
I’m dropping in a 8BA flathead in a 29 Roadster pickup. I’ll send pics of a closeup of the pulley area. The wide pulleys are no problem .. but it does get tight. I notched the crossmember quite a bit to get the engine low enough. Running a electric fan to make the belt system even more simple
Sent from my iPhone using Tapatalk |
07-15-2018, 12:17 PM | #3 |
I suggest you post your questions on;
https://www.jalopyjournal.com/ Jalopy Journal is the hot rod section, Ford barn Model A section is for 4 cylinder based cars and trucks. The owner of this site has asked to keep it that way.
I know the voices aren't real but damn they have some good ideas! Last edited by redmodelt; 07-16-2018 at 08:18 AM. |
07-16-2018, 11:25 AM | #4 | |
07-16-2018, 11:38 AM | #5 |
Charlie Stephens |
Thread Tools | |
Display Modes | |
