08-27-2017, 09:04 PM | #1 |
Rear transmission bearing retainer
I am rebuilding a spare transmission for my model A. I have several rear bearing retainers. some have evenly spaced bolt pattern where the clam shell attaches and some have unevenly spaced bolts, most have only one machined bearing holder but one has two steps. What fits the 30-31 A and what do the others fit? Thanks for the help.
08-27-2017, 09:58 PM | #2 |
Re: Rear transmission bearing retainer
Even spacing for the later transmission
08-27-2017, 10:06 PM | #3 |
Yep, I'm not sure what month the retainer changed to even spacing, but any 1930-1 should have even spacing. 1928 is uneven and has the hook over the crossmember lip.
I wonder if the change to even spacing wasn't about the same time in mid 29 when the parking brake handle moved to the right side of the shift tower. |
08-27-2017, 10:19 PM | #4 |
I have a 31 with the even spacing, just replaced with a 31 that had uneven spacing, probably had been changed by a prior owner. If not being judged, either will work but the clamshell has to all be one or the other to match that rear bearing retainer. Don't leave out the center piece of the clamshell. A friend has pulled several apart that have that important part missing. I can't believe we are that stupid, but some of us are.
08-27-2017, 10:30 PM | #5 |
The year model of your car is not the key factor, it is the type of U-joint housing assembly that is installed. The early cars had an uneven bolt pattern assembly, the later cars had an even bolt pattern assembly. After 85 plus years either can be installed.
When installing a transmission make sure the rear bearing retainer installed matches up with the U-joint housing you are going to use. Tom Endy |
08-27-2017, 11:08 PM | #6 |
08-28-2017, 06:57 AM | #7 | |
After readin' all this, I'm CONFUSED too. Up @ 3:17 AM to "P" & stayed up, waitin' fur my ANTI-PAIN-PILL & EXTRA STRONG Coffee, to "kick" IN!--BARELY remembered HOW to log in???? Groggy Bro Bill W.
