11-09-2012, 08:33 PM | #1 |
Spring Safety
I need to restore a set of springs (non-Ford) on the front of a car I am finishing. I think they are mid teens Chevy. I think they are held together by a bolt through the stack of springs. There are a couple of smaller brackets that go around the springs too. You know my question, are the springs under pressure and will they come apart and do me great bodily harm when I loosen the bolts?
Is it better to paint the springs apart or as a unit? Also, I have read some of teflon spring liners. Are these worthwhile and where would I get them? Thanks.......................... |
11-09-2012, 09:01 PM | #2 |
Re: Spring Safety
Put the spring in a big vice, verticaly with the bolt in ront of you begin to loosen it after it open a quater inch releas vice. Keep dping this untill all the pressure is released
11-09-2012, 09:07 PM | #3 |
Re: Spring Safety
a few large c clamp and the spring wrapped in a length of chain and bolted together will also do the trick .
Please call or email while website is down! 412 867 1659 [email protected] https://www.facebook.com/flop.custom |
11-09-2012, 10:09 PM | #4 |
Re: Spring Safety
Ok great advice. What about using liners between the leaf's and painting individual springs or as a unit?
11-09-2012, 10:47 PM | #5 | |
Re: Spring Safety
Get it at any industrial plastic supply. Comes in rolls. We use 1/16 x 2. Paint is NOT a good option for a bearing surface. You want things slippery. We glass bead the leaves and then Parkerize them. Most plating companies can do this. Oil lightly on assembly. |
11-09-2012, 11:06 PM | #6 |
Re: Spring Safety
