Old 05-25-2020, 06:53 AM   #1
shew01
shew01's Avatar
Default Differential Drip
My bottom differential plug usually has one drip of oil on it. I need to change the fluid, and I’m wondering if some Teflon tape around the plug would help the drip.
What do you think?
shew01 is offline   Reply With Quote
Old 05-25-2020, 06:57 AM   #2
30 Closed Cab PU
Default Re: Differential Drip
Not sure about Teflon Tape, but if you do use it use teh version in teh yellowish tape container which is rated for gas and oil. Not the white which is for plumbing/water.
30 Closed Cab PU is offline   Reply With Quote
Old 05-25-2020, 07:06 AM   #3
28 fast faton
What about using a bit of blue silicone
28 fast faton is offline   Reply With Quote
Old 05-25-2020, 07:09 AM   #4
shew01
shew01's Avatar
Thanks for the tip. I had not thought about that.
Old 05-25-2020, 07:13 AM   #5
shew01
shew01's Avatar
I don’t have blue silicone, but I do have Hylomar.
https://smile.amazon.com/gp/aw/d/B00...b_b_asin_title
Would this work?
Old 05-25-2020, 09:47 AM   #6
duke36
teflon white Permatex thread sealer is another option for bolts that penetrate the oil / lube reservoir areas
duke36 is offline   Reply With Quote
Old 05-25-2020, 10:25 AM   #7
john in illinois
john in illinois's Avatar
It is a pipe thread. Any sealant should work fine.
John
Welcome each day
john in illinois is offline   Reply With Quote
Old 05-25-2020, 10:49 AM   #8
Jack Shaft
Pipe dope or Rectorseal. Teflon tape was developed during the manhattan project,to seal massive pipe racks used to separate isotopes of uranium.
Jack Shaft is offline   Reply With Quote
Old 05-25-2020, 11:21 AM   #9
Patrick L.
Patrick L.'s Avatar
yep, pipe dope.
Old 05-25-2020, 02:06 PM   #10
30 Closed Cab PU
I still do not think the white stuff is good for gas and oil. Used some tape once on a Carb float valve because I suspected gas was leaking past the threads and shim washers. Next day my truck was running poorly. Pulled teh lower carb half off and the gas in the bowl was whitish, some of the Teflon tape had partially dissolved in the gas
