01-03-2013, 04:44 PM | #1 |
Vibration / Under powered
Let me begin by saying that I know there are multiple answers for my questions and diagnosing a problem such as this with out putting hands on the car is difficult at best. I have my ideas about what is wrong, however, I am sure that the collective knowledge and experience of the Ford Barn will produce a few new ideas to consider.
I have a vibration that begins around 800 - 1000 RPM. Below this RPM level I do not notice the vibration. It happens sitting still, in gear or out of gear, clutch in or clutch out. I also get a sight whine when driving in first and second gear, but not in third. And finally the car seems to max out at 45 MPH. At this speed the vibration is in full swing. There is no knocking associated with the vibration, just shaking. Details; 1930 Town Sedan; <500 miles on rebuilt touring engine from H&H, Mitchell transmission, purchased a rebuilt U-joint, had the flywheel balanced (but not by a model A guy/shop). Thanks for your time, Chris
" . . . these changes aren't permanent, but change is." - Neal Peart |
01-03-2013, 04:50 PM | #2 |
Re: Vibration / Under powered
Here is my 2 cents worth...The under power may be due to point gap and/or timing. It is possible that a valve(s) have closed down. If you are not getting a vibration in nuetral and not going anywhere that should leave out the tranny on back. Good Luck.
Mike
1930 TownSedan (Briggs) 1957 Country Sedan |
01-03-2013, 05:12 PM | #3 |
Whine in first and second gear is normal. Transmission gears are straight cut in the model A and they whine. No whine in high gear, be cause no meshed gears are under strain, it is direct coupling in high.
Vibration that is excessive is often caused by out of balance rods. Some vibration is normal, it is a 4 cylinder engine, and all 4 pistons stop and restart every half revolution, which causes vibration at certain speeds. |
01-03-2013, 05:13 PM | #4 |
I was going to say the center main, but 500 miles on a rebuilt engine should eliminate that............I'd hope.
01-03-2013, 05:15 PM | #5 |
Does it sound like irregular ignition? Like pistons are firing sporadically? I'm wondering if the points are making reliable contact. Perhaps the points spring is missing or not engaged and the points are flopping around and not making positive contact between cam lobes.
Ray White |
01-03-2013, 05:32 PM | #6 |
I am going over to my Dad's house and will listen carefully, but it seems that all cylinders are firing normally. I'll get back to you guys about that one. Thanks again, Chris
01-03-2013, 05:40 PM | #7 |
Whenever you are in the neighborhood, stop by & take a look at the center main cap I took out of my H&H engine with 2500 milles on it!
01-03-2013, 05:58 PM | #8 |
CarlG, believe me when I say if I had the time and means to get get to Alaska to check out your center main, I would already be booking my flight. I have always wanted to see Alaska!
Do you have a picture? What happened? Thanks for your reply, Chris
01-03-2013, 06:36 PM | #9 |
PM sent
01-03-2013, 06:57 PM | #10 |
I wonder if the vibration is from the u-joint. Does it vibrate revving the motor in neutral?
As for low power, others will surely chime in. |
01-03-2013, 07:57 PM | #11 |
One day while on a search for vibrations, i discovered that a prior owner had tightend the front motor mounts down so tight that the springs could not offer any kind of vibration absorbtion. I backed the nuts off a couple of turns, re-keyed them and eliminated one of my most serious vibrations.
01-04-2013, 11:40 AM | #12 | |
I'll also check the front motor mount. Thanks for all the help. We'll get this one yet! Chris Hall
01-04-2013, 12:16 PM | #13 | |
Have you tried this?
http://www.abarnyard.com/workshop/timing.htm
Ray White |
01-05-2013, 01:49 PM | #14 |
Newshirt
I did get a little bit of forward and aft movement out of the distributor. There was no movement side to side at all. And it was the whole distributor moving not just the cam. I'll be checking that out today. Thanks for the help. Chris
01-05-2013, 05:03 PM | #15 |
Well, we re-timed the Town Sedan today before the football game started and were able to get some positive results. We followed Marco's instructions to the letter, it ran much smoother and we picked up a little speed.
It still has the vibration, although some what reduced. I'm sure that the vibration is coming from the flywheel. Either not balanced correctly or not mounted correctly, we'll soon find out! Thanks to Newshirt for steering me towards Marco's site, and thanks Marco for the informative web site. Chris
