08-27-2019, 01:13 AM | #1 |
what caused radiator failure?
my newly installed radiator sprung a leak. It appeared where the core is soldered to the top tank but the repair shop said it was the inlet pipe attached to the tank.
I had wondered if I had left the cleanser vinegar in the system too long. The radiator repair shop said maybe or maybe a manufacturing fault, it was not possible to tell. I am starting to wonder if it was the ridgidity of the rubber hose. the motor moving along plus engine vibration? Or forward movement from the drive train especially since float a motor allows more movement. The radiator is mounted at the base with springs attached to the bolts as it should be. I have purchased new softer radiator hose which may reduce transmission of vibration and movement to the radiator. Does any reader have a comment or idea.
I know many things, But I don't know everything, Sometimes I forget things. And there are times when I have a long memory. |
