04-16-2011, 06:32 PM | #1 |
Shim Problem??
I just put a '32 Brookville roadster body on a stock original '32 chassis. All the holes lines up just fine, I have alignment problems. The LH door is sucked in at the bottom and is misaligned at the top, the RH door is bulging out at the bottom. I know this needs to be shimmed but which bolts should I start with??
04-16-2011, 08:02 PM | #2 |
Re: Shim Problem??
