09-16-2019, 02:49 PM | #1 |
Head bolt washers
On a 1935 with cast iron heads should there be washers under the nuts?
Sent from my iPhone using Tapatalk |
09-16-2019, 02:57 PM | #2 |
Re: Head bolt washers
In my 1938-41 Chassis Parts List the pictorial shows a washer along with the stud and nut. However, in the pictorial, there is no separate part # given for the washer. Given the choice, I would use a washer. More astute folks will provide best answer.
09-16-2019, 04:14 PM | #3 |
According to Green book, 21 stud 33-37 uses (351428-S7) washer on Aluminum heads only.
09-16-2019, 05:15 PM | #4 |
Only when installing aluminum heads were washers incorporated. No need when utilizing iron heads.
09-17-2019, 07:09 PM | #5 |
1935 and 1936 Chassis parts books show (42) 351428-S-7 washers used on both alum. and cast iron heads. Washers may have been eliminated in later years on cast iron heads.
09-17-2019, 08:11 PM | #6 |
This certainly supports assumption they were used on iron heads from 1935-38. |
09-18-2019, 06:28 AM | #7 | |
Thanks, Gary in N.Y. P.S. Here's a shot of them with some OEM bolts, you can see they would almost be "invisible", but they do work!
http://www.stromberg-bulletin.com/me...berg-equipped/ |
09-18-2019, 07:35 AM | #8 |
I have used (military spec) MS20002-7 flat washers in the past.
At the time they were about 10¢ each. |
09-18-2019, 08:59 AM | #9 | |
09-18-2019, 09:52 AM | #10 | |
The O.D. on the washers is .675". May be difficult to see clearly but the photo below shows the entire washer sitting inside the chrome nut! Thanks, Gary in N.Y. P.S. Not sure if ARP has them in stainless in the same size, I doubt it though? Will give them a call later in the day, they're out on the west coast, and report back!
09-18-2019, 12:35 PM | #11 | |
09-18-2019, 03:28 PM | #12 |
You can get ss AN flat washers in .745 OD for .06 each.
09-18-2019, 03:49 PM | #13 |
Would you mind posting the source for those, I'd be interested in a reliable vendor for SS hardware.
My school colors are black and blue, I attended the School of Hard Knocks where I received a Masters Degree in Chronic Mopery. |
09-18-2019, 03:59 PM | #14 |
09-18-2019, 09:34 PM | #15 |
Check out a post by Tim Ayers above about source of ARP bolts - Allens fasteners. They list all kinds of stuff.
09-18-2019, 10:08 PM | #16 |
Getting back to the original question.....Here is the correct washer used in the 1935-36 time frame.
09-19-2019, 07:54 AM | #17 |
I have never(to the best of my memory) disassembled a 35-36 iron head engine which had flat washers.
09-19-2019, 08:18 AM | #18 |
To answer many of the above posts about the washer availability, the O.P. wanted the washers to fit completely under the acorn nuts, the largest O.D. to fit that number is the size I posted in my original post, .675", anything larger will NOT go!
Thanks, Gary in N.Y. P.S. ARP doesn't make them in the necessary size in stainless, only the "block-ox" ones. Their smallest O.D. for the stainless 7/16" washers is .812", these will not go with the acorns! They are also 120" thick. The ones we do have here for 7/16" bolts/studs with the correct O.D. (.675") come in either .062" or .120" thick.
http://www.stromberg-bulletin.com/me...berg-equipped/ Last edited by GOSFAST; 09-19-2019 at 08:20 AM. Reason: C |
09-19-2019, 08:42 AM | #19 |
The OP wanted to know if washers were used on 1935 cast iron heads.
09-19-2019, 10:06 AM | #20 | |
Thanks, Gary in N.Y. P.S. Not really sure you'll find any stainless washers the needed size, 7/16" I.D. by .675" O.D. We use our black ones for rod bolt washers! If you search for 7/16" rod bolt washers you may find them in stainless, I just don't know!
