Old 11-11-2016, 10:24 PM   #1
coatings03
Smile cowl post installation-speedster
Hello everybody,
I have some questions about the correct way to install the 29 roadster left and right cowl post. I have studied the post and the bracket that holds the cowl post to the sub rail, when the firewall slides into the sub rail does the bottom bracket fit on the bottom where the sub rail and firewall meet. I will have to drill 2 holes for the 7/16" carriage bolts to go through.
Is this the correct way?
Also,installing the gas tank on the firewall cowl the cross brace and the butterfly brackets holding the dash rail? together I have not figured out that part yet. Any help is appreciated.
The deadline to complete the speedster is May of 2017.
Thanks,
Jim M.
coatings03 is offline   Reply With Quote
Old 11-11-2016, 11:21 PM   #2
tbirdtbird
Default Re: cowl post installation-speedster
"Also,installing the gas tank on the firewall cowl the cross brace and the butterfly brackets holding the dash rail?"
there is a question buried in here but it is not clear what it is
'31 180A
tbirdtbird is offline   Reply With Quote
Old 11-12-2016, 12:06 AM   #3
coatings03
Sorry, 1928-1929 style speedster
My question: Is this the correct way to install the cowl posts and placement of the holding brackets?
Second question: what is the correct way to installing the gas tank using the cross brace and butterfly brackets?
Old 11-14-2016, 01:09 AM   #4
Randy in ca
Randy in ca's Avatar
Here's some pictures of this area of the open bodies. If what you need to know isn't shown here, I've got lots more pictures. The cowl post bottom bracket was attached to the subframe with 3 rivets, and the post itself also had 2 rivets on the outside into the subframe. The gas tank was bolted to both the firewall and the cross brace and bolt/clamps were used to secure it to the top of the cowl panels. Not sure what you're calling the butterfly brackets, but guessing that they're the ones near the top of each cowl pillar - these are used to attach the interior finish panel that covers the cross brace. I've got lots more pictures if what you're looking for isn't shown in these.
Randy in ca is offline   Reply With Quote
Old 11-14-2016, 02:40 PM   #5
coatings03
Randy,
This help a lot in determining the position of these post brackets. If you
Have more pics, this will help.
Thanks Jim m
Old 12-24-2016, 01:20 AM   #6
coatings03
Smile Re: cowl post installation-speedster
Randy,
Could you please send me additional pictures of the 29 roadster cowl post position near the gas tank and how they line up with the side fire wall cowl.
Thank You,
Jim M.
