11-23-2012, 09:33 AM | #21 |
Re: What is this noise?
4 clicks per revolution sounds like it is in front of the rear. Indicates a 3:78 rear and sounds like the pin in the shaft coupling pin. I have seen a number of these pins come loose. They slide out as the drive shaft turns and hit the torque tube. The pin is to long to drop out. I doubt this can be repaired by drilling a hole in the tube as someone mentioned. A peice of heater hose is good for listening. G.M.
www.fordcollector.com |
11-23-2012, 09:47 AM | #22 |
Pulling just the one side was a suggestion I made when I thought it was in the rear, rather than the driveshaft area. On balance you'd probably do better to pull the whole rear and give it a thorough checkover considering the long journeys you like to make.
Mart. |
11-23-2012, 10:32 AM | #23 | ||
As I said earlier, my "stethoscope" indicated it is inside of the differential at the same frequency as the drive shaft so most likely a pinion gear bearing.
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness |
11-23-2012, 10:38 AM | #24 | ||
Must be something in the water on our street that Chuck and I both have had rear end problems this year.
11-23-2012, 12:35 PM | #25 | |
11-23-2012, 01:54 PM | #26 |
https://www.youtube.com/watch?v=h1P1B...ature=youtu.be Whadaya think? Here's a picture of the liquid gold I drained out of the differential - clear sign of metal wear inside. (That oil was just new before our trip.) You can really see the sparklies on the plug.
11-23-2012, 02:56 PM | #27 |
What does it do in reverse?? (There might be answer to my question up above, but...)
11-23-2012, 04:14 PM | #28 |
Reverse is no different.
11-23-2012, 04:38 PM | #29 |
My hat is off to you sir for driving a 65 year old car regularly. Things happen in old cars. This is one of those things. Fix it once, fix it right. It will be good for the rest of your time.
11-23-2012, 04:42 PM | #30 |
I'm not sure if that rear has "spider gears" or not but I had the exact same noise come out of a Dodge rear. It was the shaft that runs through the spider gears. The keeper pin broke and the shaft would move back and forth, but to long to fall out. Just saying.
11-23-2012, 04:48 PM | #31 |
I do have spider gears and will certainly check those when we get it apart. Thanks for the tip.
11-23-2012, 04:54 PM | #32 |
The early ford rear does not tend to suffer from that sort of pin drifting out problem because it has 4 pinions on a forged cross shaped pin thing.
Don't rule anything out though. Mart. |
11-23-2012, 10:50 PM | #33 |
Sonny - I think spider gears are a requirement for most, if not all, differential gear set-ups. FWIW
11-23-2012, 10:53 PM | #34 |
Even my walk behind self propelled mower has them. If it's a differential rather than solid axle (like some ATV's) it's got spider gears.
11-24-2012, 11:35 AM | #35 |
Run a Magnet through the oil. If it's metalic the magnet will remove the particals. G.M.
11-24-2012, 12:31 PM | #36 |
Take it to Chucks up the street and work on it there.
11-24-2012, 05:22 PM | #37 |
Henrykokomo, I'm familiar with the workings of a differential I used to set up rear ends for racing. I asked about the spiders because I have also locked up rears without spiders. FWIW
11-24-2012, 07:37 PM | #38 |
All "open" diffs have spider gears, Sonny was referring to a non Ford type diff having the pin that the spiders run on come loose and start to come out, hence making a noise. These diffs have two spiders and a single pin. Early Ford diffs have spiders, but 4 of 'em on a cross shaped pin forging. Hence in a ford diff the problem of the pin coming adrift cannot happen.
Mart. |
11-24-2012, 08:05 PM | #39 |
I did run the magnet through the oil. I didn't think it would pick up anything because I thought all of the shiny specks were brass colored but I couldn't think of what in the banjo would be that color. Well, turned out all of the shiny specks that clung to the magnet were silver colored steel - they only looked gold because of the color of the oil. So, definitely have something steel wearing out in there. Hope to find out what tonight.
11-24-2012, 08:15 PM | #40 |
Sonny, please don't confuse us with Dodge knowledge. We're working overtime here just to keep up with our Ford stuff!
Alan |
