10-09-2017, 03:25 PM | #1 |
What is this hole???
Can someone please tell me what this hole is for near drivers left foot? I also see two other holes on firewall that have been filled. I think the one on the right is for starter, the other I'm not sure... any help?
10-09-2017, 03:27 PM | #2 |
Re: What is this hole???
It looks like someone installed a headlight dimmer.
Rusty Nelson |
10-09-2017, 03:53 PM | #3 |
Mine has the same thing, but a little lower. '29 Tudor.
10-09-2017, 04:02 PM | #4 |
I was thinking headlight dimmer but, I thought this was done by the light switch on horn ring. Mine is a '31 roadster.
10-09-2017, 04:09 PM | #5 |
I've seen a foot operated horn button mounted there. It was on a car I was test driving and couldn't work out why the horn sounded at the weirdest times!
10-09-2017, 04:25 PM | #6 |
Maybe the owner fitted an accelerator pedal there? The middle pedal is a PITA. |
10-09-2017, 05:00 PM | #7 |
All dimmer switches I have seen have symetrical holes.
This is a normal Ford ('40-'48) dimmer switch hole pattern. |
10-09-2017, 05:01 PM | #8 |
The odd hole alignment is what Ford used on later flatheads for the headlamp dimmer.
10-09-2017, 07:10 PM | #9 |
Ford ('38-'48) dimmer switch
10-10-2017, 12:29 AM | #10 |
Excellent... Thanks!
