11-29-2018, 08:04 PM | #1 |
wheels
On my 1930 pickup if I wanted to run 15'' inch tires , what ford wheels would fit? Thanks
11-29-2018, 08:44 PM | #2 |
Re: wheels
Ford pickups, until at least 1957 had 5 on 5-1/2” bolt circle. I think the pickups used that pattern for even many more years. My favorite wheels are the 1949-51 Mercury wheels, or the same year Lincoln’s. Mercury was a 5-1/2” width, and Lincoln a 6” rim width. For my A, I used a set of Mercury wheel centers and had Wheelsmith put on new rims that were better widths for the tires I was using.
11-29-2018, 10:48 PM | #3 |
Re: wheels
www.whidbeymodelaclub.com |
11-29-2018, 11:05 PM | #4 | |
Re: wheels
11-29-2018, 11:16 PM | #5 |
Re: wheels
If you are still running mechanical brakes you will probably need a spacer/adapter as the later disc wheels are designed to be mounted on a flat drum. Leaving this spacer out is dangerous.
Charlie Stephens |
11-29-2018, 11:54 PM | #6 |
Re: wheels
11-30-2018, 10:50 AM | #7 |
Re: wheels
Thanks everybody.
Thread Tools | |
Display Modes | |
