10-20-2014, 04:33 AM | #1 |
81A engine query
I have just removed the sump plug on an 81A engine to do an oil change and was amazed to find what looks to be the oil pump pickup screen and clip hard down across the hole where the sump plug goes.
I tried to push it with a screwdriver to see if it would move but it will not. Is this normal? I would have thought there would be clearance between the bottom of the screen and the pan. If it is not normal, is there a chance that someone has installed a deeper pick up tube without checking the clearance and what do you think about running the engine? It must have been like that for a while and I really don't want to pull the sump if possible. Any comments and / or advice would be appreciated |
10-20-2014, 04:51 AM | #2 |
Re: 81A engine query
I think you've got the answer, probably some one has installed 8BA oil pump and a truck pickup tube, usually you have to heat that tube and bend it up tom clear the pan. Walt
10-20-2014, 08:55 AM | #3 |
