Old 04-07-2013, 06:46 PM   #1
fomocoloco
Default installing clutch on 36
when installing a clutch, is there a trick to adjusting the 3 fingers on the clutch?
fomocoloco is offline   Reply With Quote
Old 04-07-2013, 06:58 PM   #2
ken ct
Default Re: installing clutch on 36
Yea LEAVE THEM ALONE // They are set by the rebuilder. Contact "Fort Wayne Clutch " ford wayne ind. ken ct.
ken ct is offline   Reply With Quote
Old 04-07-2013, 07:02 PM   #3
ford3
Kens right, if its american made its pre adjusted, dont touch unless you want to pull trans and every thing again
ford3 is offline   Reply With Quote
Old 04-07-2013, 07:13 PM   #4
fomocoloco
Please pardon my ignorance, but how do those 3 fingers, at 3 different heights, work?
Old 04-07-2013, 07:22 PM   #5
ken ct
There not supposed to be at diff hights.Poorly made clutch in my opinion. Ken ct.
Old 04-07-2013, 07:33 PM   #6
fomocoloco
So, if I buy a clutch and the 3 fingers are at 3 different heights, what do I do?
Old 04-07-2013, 07:49 PM   #7
Hank the 36
Good info for the future fomocoloco, can you take some pics and add to post.
Thank you,
H36
Hank the 36 is offline   Reply With Quote
Old 04-07-2013, 07:50 PM   #8
ford3
quick answer, send it back, you already have a major problem, one that you probably cant correct, if you dont have experience adjusting them chances are you will never get it right, i repeat, send it back and buy one that is american made or rebuilt, same with clutches, if foriegn made its probably to thick and will never work right
Old 04-07-2013, 08:05 PM   #9
fomocoloco
Thank you all for the advice. I'll order from Ft. Wayne.
