07-12-2015, 08:34 AM | #1 |
check for straight wheel
how to check for straight wheel,seems can feel a wheel not running straight,all look ok following behind
07-12-2015, 09:10 AM | #2 |
Re: check for straight wheel
I would just jack up the wheel in question and spin it. Runout (radial in and out) and side to side should be 1/8" or less.
Also look at the line on the tire near the rim to be sure the tire is correctly seated. WD-40 or Vaseline on the tire bead will help greatly in making it seat correctly. |
07-12-2015, 10:08 AM | #3 |
