07-03-2017, 01:14 PM | #1 |
dumb question of the day
does the distributor from a ford 239 ci fit a mercury 255ci engine?
07-03-2017, 01:26 PM | #2 |
Re: dumb question of the day
Yep, the engines are the same except for the Merc 4' stroke. The distributor is controled bt Vacuum only. So make sure it working.
07-03-2017, 01:33 PM | #3 |
thanks ron we were all standing around shooting the crap when that question came up i said someone on ford barn will know. half of us were right.ha ha thanks again
07-03-2017, 02:14 PM | #4 |
Keep in mind there were two types of distributors used on 8BA family engines in the time frame of 1948 through 1953. The old 7RA type distributor 1948/50 Ford car/truck will not fit in an OCM type (1950 & later Merc) aluminum front cover and visa versa. After 1951 or so they were generally using the OCM types but I don't know about Ford trucks.
Another difference is the type of carburetor since the Holley Load-O-Matic spark advance was controlled by the carb. I think that the advance curve was pretty much the same though so it doesn't make all that much difference. If a person changes distributors, they have to consider the type of front cam chest cover. |
07-03-2017, 02:20 PM | #5 |
Some good info here. Need to have your front cover match your distributor.
https://www.fordbarn.com/forum/showt...+timing+covers rotorwrench beat me to it but still a good illustration of the differences. Mike.
Ignorance of the laws of physics does not mean they do not apply to you. Last edited by 29AVEE8; 07-03-2017 at 02:35 PM. |
07-04-2017, 09:44 PM | #6 |
