Old 06-13-2019, 04:44 AM   #1
Flathead21
Default Old Herbrand Tool for pulling heads off Flathead V8's.
Hi Guy's.
Got this old time tool set from an old time mechanic who said it was for pulling off the stuck on heads on Flathead V8's; but he didn't know much more about it.
There are 2 pairs of long studs. One pair of long studs is threaded for 18mm sparkplug thread on the end; & the other pair of long studs are 14mm sparkplug thread. I guess you screw a pair of long studs into the plug hole on the head; depending on which size your plug thread is.
There are 2 bridges with a large square hole in them. I guess that they go over the long thread that would be sticking up out of the head. I guess the bridges sit down on the head studs(?). I reckon that you then put the washer & nut onto the long studs, & wind the nut down onto the top of the bridge; & that then pulls the head up enough to get under it, & get it off.
The bridges are stamped HERBRAND 2390.
My question is, would anyone out there have a copy of any original instructions for the tool, or an old catalogue picture / advert for it?
Or, a picture of a complete set; or even any information at all. What date / era would it be? Am I missing any parts for it?
It'd be great to have some information or thoughts on it, so as I can put it back to use again.
Thanks, Dave.
Flathead21 is offline   Reply With Quote
Old 06-13-2019, 05:00 AM   #2
51 MERC-CT
51 MERC-CT's Avatar
Default Re: Old Herbrand Tool for pulling heads off Flathead V8's.
Yes was used on Flathead Fords but may be universal and work on any non-Ford flathead engine.
Old 06-13-2019, 06:24 AM   #3
mfirth
I have seen some parts of this tool set in some of my dad's old stuff, but didn't know what it was. I have a couple of Herbrand tools and i think they were located in Fremont Ohio.
Thanks for posting. mike
mfirth is offline   Reply With Quote
Old 06-13-2019, 08:41 AM   #4
D. Jones
D. Jones's Avatar
Interesting tool. If there is a patent number on it you can look up the patent application on-line and it should have a good description of how it works. That's how I identified the armature lathe I found at a yard sale.
D. Jones is offline   Reply With Quote
Old 06-13-2019, 10:33 AM   #5
Jack E/NJ
Jack E/NJ's Avatar
From https://archive.org/stream/HerbrandC...052-M_djvu.txt
Jack E/NJ
No. 2390 ''Van-Chrome'^ Ford Cylinder Head Puller For Easy Lifting of Rusted and Corroded Heads Drop Forged from Chrome Vanodium Steel Mechanics encounter difficulty and resulting loss of time when removing aluminum heads on Ford V-S's because of corrosion and rusting of studs. Parts arc frequently damaged because heads are on so tight that ‘‘chisel and pry’* methods are applied, which cause costly replacements due to breaking heads and cracking blocks. This specially designed Herbrand Puller removes the head with an even, positive pull, regardless of how tight they may be sealed to the block. The cost of these pullers will be saved on the first job, and they lick flat rates to a standstill. The crossarms of these Pullers bridge the cylinder head, the adjusting screws on either end line up with, and rest on top of, the cylinder head studs. The main forcing screws turn into the spark plug holes, then pressure is applied to the hex pulling nuts alternately with a wrench, and the head responds quickly and easily to the pulling power of the forcing screws. Always used in pairs, these Pullers consist of 2 crossarms, equipped with 2 adjustable levelling studs; 2 collars; 2 hex turn-down nuts and 4 forcing screws: 2-14mm for V8-60 and 2-18mm for V8-85. For V8-85 use levelling stud in end of crossarm; for \^8-60 use center stud hole Satin nickel. Weight 5 lbs.
Old 06-13-2019, 04:33 PM   #6
Lawrie
Lawrie's Avatar
BY the looks of it you have the whole set minus the box.
I have the same set in its orig box,it works well
Lawrie
Old 06-13-2019, 07:31 PM   #7
Flathead21
Hello again Guys,
Thanks for the replys.
That's interesting Jack. Thanks for posting that info. What year Herbrand catalogue is that from?
I have a 1937 Herbrand catalogue, & this tool isn't in there.
Is there a picture of the 2390 tool in your Herbrand catalogue; & if so, could you post that?
Lawrie, I see that you're in Australia too.
Would you be able to send me a few photos of your tool; & it's box?
The crossarms or bridges on mine seem to have had the fixed pins on the end ground down, so it would be good to see what the correct length ones look like; so as i can re-make mine.
Thanks guys,
Dave.
Old 06-13-2019, 08:50 PM   #8
Jack E/NJ
Jack E/NJ's Avatar
The link posted earlier suggests ca 1940. Catalog 52-M. Jack E/NJ
HERBRAND TOOLS ARE MADE IN CANADA SECO SALES and SERVICE, LTD. 90 Sherbourne St. Toronto, Ontario Copyrighted 1940 Printed in Canada
Old 06-14-2019, 05:01 AM   #9
richard crow
does it come with a stick of dinamite
richard crow is offline   Reply With Quote
Old 06-14-2019, 03:56 PM   #10
JSeery
JSeery's Avatar
LOL, the next best think is built-in! Loosen the bolts/studs and turn it over and off they come.
Old 06-15-2019, 06:32 AM   #11
richard crow
JSeery back in the 1950,s my father had a 36 ford with alum heads. he wanted to do a ring job . he removed all the nuts head would not budge. so he decided to start the eng no luck. he drove the car back & forth for a week no luck. he put the nuts back on & drove the car witched smoked & burned oil. he junked the car a year later
Old 06-15-2019, 07:04 AM   #12
JSeery
JSeery's Avatar
That's interesting, normally they pop right off. The heads must have been totally fused to the block!
