Old 01-09-2019, 10:38 PM   #1
louvers
louvers's Avatar
Default 40 Ford car dash
I have just aquired a 40 car dash, its missing the ash trays, glove comp door and instrument cluster. How can I tel if its a standard or deluxe?
thanks
louvers is offline   Reply With Quote
Old 01-09-2019, 11:26 PM   #2
deuce_roadster
deuce_roadster's Avatar
Default Re: 40 Ford car dash
Deluxe dash has holes for the horizontal chrome strips that the V8 (std) dash lacks. Same goes for the deluxe glove box door that also has a hole for the clock.
Old 01-09-2019, 11:39 PM   #3
TomT/Williamsburg
TomT/Williamsburg's Avatar
And, if you are not trying to be stock, I like to see the Deluxe dash with the standard gauges and the chrome strips. I have modified a standard glove box door for the Chrome strips but no clock. I put a V8 insignia where the clock would be instead. Makes for a really nice looking dash .....
TomT/Williamsburg is offline   Reply With Quote
Old 01-10-2019, 02:45 AM   #4
mercman from oz
mercman from oz's Avatar
Here are some photos of the Deluxe and Standard 1940 Ford Dashes. Notice that the Instrument Panel is different, and the Deluxe Dash is two-tone and has the Clock plus extra chrome strips as previously mentioned.
Old 01-10-2019, 09:39 AM   #5
deuce_roadster
As you can see by the excellent pictures, the deluxe holes for the chrome strips are above and below the ash tray openings on a completely empty dash. Both dashes have holes for the radio speaker grille.
Old 01-10-2019, 10:03 AM   #6
TJ
TJ's Avatar
In addition there are two types of ash trays. The early ash trays have the "tip up" lids and a triangular ash tray insert in the lower part of the ash tray opening. The later ash trays are the "tip out'" type with the ash tray receptacle attached to the lid. Before you buy ash trays you need to know which ones you need. The late "tip out" type are reproduced, the early style are not.
Old 01-10-2019, 12:44 PM   #7
louvers
louvers's Avatar
Thanks just what I needed to know!
Old 01-10-2019, 01:06 PM   #8
mercurycyclone
40 Ford Ash Trays Early & Late.
File Type: jpg 5EE9EE1F-73D5-41C4-A4E7-886E7C97D2F0.jpg (49.1 KB, 73 views)
File Type: jpg 3669FD80-73F1-49FD-8BBE-A8375E2891F8.jpg (45.9 KB, 72 views)
File Type: jpg D999A8B0-1515-409D-889A-CF1E8A76E763.jpg (44.6 KB, 69 views)
mercurycyclone is online now   Reply With Quote
Old 01-12-2019, 12:04 AM   #9
Fred A
Fred A's Avatar
The Deluxe is an early convert. I think Kube dates the early ash trays into January. Another clue on early is the grille sides. Good Luck: Fred A
Fred A is offline   Reply With Quote
Old 01-12-2019, 01:51 AM   #10
mercman from oz
That is all very interesting. Now that you mention it, check out these two 1940 Ford Deluxe Dashes. Note different locations of the Knob to open them. One is at the bottom while one is at the top. with these old Fords, you can never take anything for granted. Thanks for pointing out this difference.
Old 01-13-2019, 06:30 PM   #11
19Fordy
19Fordy's Avatar
The first photo ashtrays (early production) push in and up. The second photo ashtrays (later production) pull outward.
Hence, the location of the knobs are different.
Old 01-18-2019, 04:09 PM   #12
Automotive Stud
Automotive Stud's Avatar
While we are on the subject, is there any difference between closed and open car dashs?
Automotive Stud is offline   Reply With Quote
Old 01-18-2019, 08:19 PM   #13
russcc
I like the simple Standard dash.
Old 01-18-2019, 08:29 PM   #14
STEVE O
STEVE O's Avatar
The conv. and woodie dash differ from the other 1940 dash's. There is a little difference in width and shape on the sides at the door posts are a little different.
STEVE O is online now   Reply With Quote
