05-20-2013, 12:18 PM | #1 |
Speedo Cable Issues
Just installed a new speedo cable and it has been running great. Went on a club meet this past Saturday and everything was running great the whole day. Then all of a sudden I heard a noise and noticed the MPH was at 0 while I was driving. Looked at it last night and the cable had broke at the end that goes into the tranny. Any ideas what would have caused this or what I can do different for when I try to put the next cable on?
Thanks, Neal
1929 Model A Ford Coupe |
05-20-2013, 12:21 PM | #2 |
Re: Speedo Cable Issues
The cable may have been dry and the friction was too great for the connector. Did you lube the cable?
Ray White |
05-20-2013, 12:23 PM | #3 |
No it was a brand new cable and casing. Should it have been pulled and lubed? If so it is my fault and you live and learn, but when I tested the cable it turned very easily.
05-20-2013, 12:31 PM | #4 |
I'm afraid that it was lack of lube too. I have purchased cables both ways, some with lube and some without. I always check and lube anyway, even if they come with some on them, just so I know it's done my way.
But it could go back to your speedo too. Is it rebuilt? If not, even if it was working, if it has old hardened grease in it it might have reached a resistance point and jammed, thereby kinking and breaking the cable. It's surprising how hard that grease can sometimes be.
05-20-2013, 12:36 PM | #5 |
Thanks Ray. I guess I will be getting a new cable and pulling it out and lubing it up. The speedo was taken apart and appeared to be okay. Now the keyed part of the cable still appears to be in the place where you hook it to the tranny. Easily pulled out with needle nose plyers? I'm working right now and can't go look at it.
05-20-2013, 01:05 PM | #6 |
Ray White |
05-20-2013, 01:09 PM | #7 |
I could probably give that a try. Thanks for the suggestion.
05-20-2013, 01:25 PM | #8 |
I had the same thing occur. The speedometer appeared to be ok. I installed a new cable to the speedometer only and then tried to turn the cable by hand from the transmission end, and it was very stiff. I opened up the speedometer and found some very old and hard grease. After cleaning it worked good.
'31 Fordor Deluxe 2W Briggs 170-B / blackwalls '41 Fordor Deluxe / 2-duece flattie '66 1/2 Dodge Charger '14 100th Anniversary Challenger Limited Edition. Semper Fidelis |
05-20-2013, 01:35 PM | #9 |
I'll second Rock's post. I snapped a few cables until I opened the bottom of the speedo itself and cleaned out the hard grease. The speedo was turning, but would occasionally bind up the smallest bit.... which is all it took to snap the cable. Even if this isn't the primary problem, I would suggest doing it as 80+ year old grease typically should be replaced regardless.
05-20-2013, 03:41 PM | #10 |
It's common for the main bearing in the speedo to seize. With speedo out & cable connection UP, fill it with penetrant & do a lot of waiting! Then turn it counter-clockwise, CAREFULLY & wait some more. In time, you can turn it ever so slowly with a reversible drill motor, then fill it with oil & wait some more. I've been BABYING mine for 5 days, & it's getting better, EVER SO SLOWLY!! When you can spin it easily with a stub cable between your thumb & forefinger, IT'S READY!! Don't RUSH it, it takes time to get the lubricant worked in & to get the bearing surfaces burnished by turning. DON'T JUST TAKE IT APART FIRST THING!! It's almost like fine clockworks. Tightness "MAY" be caused by reactions between dis-similar metals in the bearing. Bill W.
05-20-2013, 04:37 PM | #11 |
Thanks for the info Bill.
05-20-2013, 04:48 PM | #12 |
Just now turned mine, carefully, with the drill motor. Got it up to 60 MPH for 2 minutes. Trip meter & odometer workin' good. Still too tight though, will keep soaking & turning until it's REAL free. Then I can fire & drive VERMIN for the FIRST time Bill W.
05-20-2013, 06:19 PM | #13 |
Might be a redneck lube job , but I have had success with 3 speedos so far by using a 1/8th drill and drilling thru to the mainshaft thru the threaded hole at rear...the one that holds it to the case.
I got no idea what diameter this mainshaft is, but I just drilled until I reached it. Then dropped in some oil and graphite and spun it up with a drill. The dried grease at the lower gears is as bad a culprit as a dry main shaft methinks. |
05-20-2013, 07:21 PM | #14 |
I would guess the problem is in your speedometer because the cable usually breaks at the opposite end of the problem!
05-20-2013, 09:14 PM | #15 |
Part of the problem with the old speedometers is that the main frame is made of pot metal. This has an interesting property of swelling with age. The frame will grow in height and the steel shaft will remain the same length. With zero end play to begin with, it does not take much to get to tight to run. If you cannot spin the input end with your finger tips, it is too tight to run properly.
Mark in MT Always looking for another opportunity to be wrong. |
05-21-2013, 06:12 AM | #16 | |
Thanks, Tom... |
05-21-2013, 08:29 AM | #17 |
Tom, Here is a link to an old post with some photos that might be helpful.
http://fordbarn.com/forum/showthread.php?t=53013 |
05-21-2013, 09:03 AM | #18 |
I broke a cable the other day, something in the speedometer I was working on jammed, kinked the cable and broke it.
I was having problems with the inner cable going too far into the tranny to seat in the speedo. I made a nylon spacer that keeps it from falling in.
1929 Model A Barn find. California car, just a few more parts to find. Interior, steering box (rebuild), and I am sure much more! |
05-21-2013, 03:04 PM | #19 | |
Awhile ago I removed the big soft plug, grease looks good, maybe Moly Sulphide. Filled it with penetrant & turned it some. Just waiting some more. Speedo has original seal & looks as if it has never been open. It's an oval speedo with NO brand name. Bill W.
05-21-2013, 04:13 PM | #20 | |
