Old 04-10-2019, 04:31 PM   #1
Cave
Cave's Avatar
Default Rear bearing seal - spring popped out
The internal springs popped out and dropped down onto the bearing while I was installing them recently. Don't know why and hope it doesn't happen to others but here is a simple and cheap preventive step.
I wound a short piece of stranded 12ga electrical wire into the underside opening with the spring in place... drove the seal home... pulled the cheater wire out and all was fine.
Cave
Cave Luther
Syracuse, NY
1931 Deluxe Coupe (Rose)
______________________________________
"... I'm pullin' for ya, we're all in this together." Red Green
Cave is offline   Reply With Quote
Old 04-10-2019, 07:23 PM   #2
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Default Re: Rear bearing seal - spring popped out
Fill the spring cavity with wheel bearing grease!!
Bill Trick
"THE ASSISTANT GURU OF STUFF"
Old 04-11-2019, 07:57 AM   #3
Jwilli
Jwilli's Avatar
Bill Trick
Nice trick Bill.
Jwilli is offline   Reply With Quote
Old 04-11-2019, 08:25 AM   #4
Cave
Cave's Avatar
Bill's suggestion is excellent, however in my case I discovered the spring fell out after installation, I used the wire trick to help snake the spring back in with the seal in place.
Cave Luther
Syracuse, NY
Old 04-11-2019, 11:09 AM   #5
Russ/40
Russ/40's Avatar
Am I missing something? What seal is that?
Old 04-11-2019, 02:20 PM   #6
Cave
Cave's Avatar
Rear wheel hub bearing seal.
Cave Luther
Syracuse, NY
Old 04-11-2019, 06:25 PM   #7
Russ/40
Russ/40's Avatar
Dah, brain fog. I had rear main on the brain. Trying to figure how you did that. Dah
