12-01-2013, 01:34 AM | #1 |
where is the no.1 piston
Where is the No. 1 piston suppose to be when the marks on the crank gear and cam gear are perfectly lined up. The top of the piston is down in the cylinder about 1 inch. Getin old i guess Thanks Richard/Ca
12-01-2013, 08:08 AM | #2 |
Re: where is the no.1 piston
The piston will be at TDC when the pin is inserted in the cover and matches up with the cam gear dimple. So, when the marks on both gears are matched, the piston will be down in the bore but I can't tell you how far.
12-01-2013, 11:48 AM | #3 |
No. 1 front piston will be to the top of the block, remove the 1 spark plug with flashlight look in hole you will see the piston at top dead center, make sure you are not looking at the valve and the dimple should be felt when inserting.
www.whidbeymodelaclub.com |
12-01-2013, 12:01 PM | #4 |
Gary, what you say it correct for the moment the timing pin drops into the indent on the timing gear, but I think Patrick has the right answer to Richard's question.
12-01-2013, 12:36 PM | #5 |
THank you so very much Patrick L , Gary WA ,700rpm. All great answer but Patrick L's was the one I was looking for. Richard/Ca
12-01-2013, 02:25 PM | #6 |
12-01-2013, 05:54 PM | #7 |
WHERE'S # 1 PISTON? NOW, thets FUNNY, Richard! Dog here, Chief described a LOOOOSE OOOLD rattley engune, like, "Sounds like the pistones are SWAPPIN' HOLES"!! BUT, I think u'll find thet # 1 pistone is still in # 1 HOLE!!! LOL (# 1 hole is the frunt hole, when sittin' in the driver's seat, lookin' fruntways)-Buster T.
12-02-2013, 05:56 PM | #8 |
Sorry Bill I Did not ask what hole the #1 piston was in. I ask what was the location of the piston in the hole when the timing marks were lined up. My stuped I guess. Richard
12-02-2013, 06:19 PM | #9 |
I think Bill was jerking your lariat. He knew what you meant.
12-02-2013, 09:22 PM | #10 |
I think some had better reread the initial question.
12-02-2013, 11:11 PM | #11 | |
I "think" your question was, "Where is #1 piston when the marks on the cam gear & the crank gear are aligned"? Maybe I mis- read it?? Bill W. (Richard, I re-read it. Wherever the piston is, when those marks are aligned, has NO relevance to anything and is NOT important, as far as I know???) The Dog originally read the question to me, while I wuz unclogging the paper shredder, & I think he mis-read it to me
"THE ASSISTANT GURU OF STUFF" Last edited by BILL WILLIAMSON; 12-02-2013 at 11:33 PM. |
12-02-2013, 11:22 PM | #12 |
That alright Bill and the Dog. It had to smile a little when I went back to my message and found that I didn't even spell STUPID right. Sorry! Richard
12-02-2013, 11:56 PM | #13 |
Shucks, Richard, I'm beginnin' to spel & tipe like that dad burned Dog LOL Well, we need SOME kind uf reputation Meybe thats why NOBODY ever calls??????? The Dog sez I only have 2 friends left, since my good friend, Andy, passed away last week with a HUGE brain aneurysm. The Dog watches his house from the front window, waiting to bark when Andy comes out front. bILL W.
