06-02-2018, 06:48 AM | #1 |
Clutch release shaft assembly removal
Any tips/instructions for removing the clutch release shaft, pin and fork from my '48 trans.? I don't see anything about that process in the repair manual.
Thanks in advance! Dave |
06-02-2018, 07:06 AM | #2 |
Re: Clutch release shaft assembly removal
As I recall, I removed that pin with a pin punch. Take "Before" photos of the assembly.
However, I did replace it with a socket head cap screw threaded into the shaft with a nut and Loctite on the other end. That was 20 years ago. Still working fine. I think replacement pins are available if you want it 100% stock. While you have it apart replace the split bearing 7507. Also, check your pilot and throwout bearing and the "wear" on all parts that use a clevis pin for excessive play. It all adds up in clutch adjustment. http://www.vanpeltsales.com/FH_web/F...40-48_85hp.jpg |
06-02-2018, 07:42 AM | #3 |
