07-18-2018, 11:49 PM | #1 |
Any Lore About Battery Repair in Model "A" Days?
Was it really a widespread practice to open up batteries back then to replace plates etc.? Seems like a whole lot of work to drain the electrolyte, then somehow open up the tar top, etc.
The literature makes it obvious they had loads of battery issues. I know the economics were vastly different in that era but still, it seems like a lot of work to fiddle with battery repair.....labor rates then must have been peanuts to justify extensive repairs. |
07-19-2018, 07:45 AM | #2 |
Re: Any Lore About Battery Repair in Model "A" Days?
Yes, it was a somewhat common occurance because of several things. Labor was cheap back then, and so was the ability for the common mechanic to actually repair something. Because the plates were the usual issue, disassembly could be done so that the sulfated and/or loose plates could be repaired by the typical repair shop and they could get another round of service from that battery.
07-19-2018, 09:39 AM | #3 |
Just to illustrate, I have a 1947 Parts and Flat Rate Manual. Shop rates were about $3 an hour. A new piston was around $10. Today shop rates are around $80-$100 and if you shop for online specials, a new piston (for a 350 Chevy or 302 Ford) is still around $10. Back then you could knurl a worn piston skirt, machine a worn top ring groove and install a spacer, and ream or hone the wrist pin bore oversize and install a new oversize pin for far less than $10.
07-19-2018, 09:49 AM | #4 |
According to the inflation calculator, $3 in 1947 would be equivalent to about $33 today. Interesting to think about.
07-19-2018, 09:54 AM | #5 |
$3 in 1947 is = $34 today
$10 in 1947 = $114 today |
07-19-2018, 10:05 AM | #6 |
But remember, it's all RELATIVE, WAGES were CHEAP, also ! In 1959, I worked as a Journeyman, Union Mechanic at Lutz Ford, in Palo Alto, Ca, for $2.67 an HOUR! At Jorgenson Battery, here in town, rebuilding batteries was a BIG DEAL! They'd cut the cell connectors, with Horse Hoof Trimmers, place the battery under a hooded burner to soften the tar, grab on to the cell connectors or the posts & pull each cell out. If the plates were OK, they'd replace ALL the insulator plates & put it back together. They had molds, to form new cell connectors & posts. It's DANGEROUS WORK, always a chance of an EXPLOSION!!! The shop is still in business, after 3 generations of Family ownership. They supply NEW batteries for "EVERYONE", As changes in battery designs have made them UN-REBUILDABLE, except for some SPECIALTY Batteries. Bill Frequentcustomer
07-19-2018, 10:48 AM | #7 | |
07-19-2018, 10:52 AM | #8 |
The dykes manual has step by step instructions on how to do it. https://play.google.com/store/books/...YNbg0QC&rdot=1
07-19-2018, 11:40 AM | #9 | |
07-20-2018, 08:27 AM | #10 |
I also repoured battery posts when I was in the Army. When someone screws up connections on two large batteries making 24 volts, you can turn a battery post into a lead puddle in about 1/2 second.
07-20-2018, 08:55 AM | #11 |
I DISCOVERED this, on some Lucas batteries, while load testing, from post to post, with a carbon pile tester, then checking voltage of each cell with a multi-meter, one cell would REVERSE its' POLARITY!!!----WHY? I don't know.
And, the generator would NOT CHARGE, until you put in a NEW battery! Bill W.
07-20-2018, 10:08 AM | #12 |
I've been trying to locate someone in the Dallas-Fort Worth Texas area that rebuilds old lead batteries but haven't found anybody. Anyone know if they are still doing it?
07-20-2018, 10:27 AM | #13 |
If you have never had a battery explode, you have missed an important lesson. Luckily, the one I had explode was under the hood of a car, and the hood was closed. I was standing next to it when my wife hit the starter, and BOOM! The hood sort of lifted a bit, and acid was everywhere. Took the battery to Wards, where I had just bought it the day before, and they said it was not covered under warrantee, because ALL battery issues turned out to be alternator problems. I showed the manager the area where the internal connector from one cell to the other had a big arc'd area, (bad connection), and convinced him (with the help of one of there "mechanics") that it was a faulty battery. The car never really recoverred from rust issues, even with massive rinsing, and the garage floor was permanently stained a light brown. AND, I never bought another battery from Wards.
Corley ----------------- Subscribed to the KISS principle! |
07-20-2018, 10:47 AM | #14 |
07-20-2018, 10:54 AM | #15 |
So people don't get the wrong idea; the cells were hard rubber and they sat in the wood box/case. For a 6V, you would have 3 cells the were joined together in the wood case.
I know the voices aren't real but damn they have some good ideas! |
07-20-2018, 11:08 AM | #16 |
Before you do "ANY" of the above things, drain all Acid, Flush all cells with a water hose over and over. Now put A LOT of BAKING SODA in each cell, fill with water..Let it sit a few days, tapping on the sides, the lower the better, every so often.. Drain & flush well again. Now let dry upside down for several days, For this I used a welders hood, get a torch and run it over the cell fill holes, if no BOOM, your good to go.. Fix what needs be, Fill with acid, slow charge & you have a new battery..
07-20-2018, 02:51 PM | #17 |
A very common used car lot battery rebuild in the old days was, a teaspoonful of magnesium sulfate (epsom salt) in each cell. It usually rejuvenated the battery long enough to meet the 30 by 30 warranty.
07-20-2018, 06:41 PM | #18 |
There is a place here in Melbourne where batteries are still rebuilt mostly for people looking for originality in their restoration. They are constantly in search of usable hard rubber cases.
I remember my father getting 19 years out of a rebuilt battery he bought in the late 50s. Seems recycling was done better in the "bad old days" than now.
07-20-2018, 11:43 PM | #19 | |
During my high school years I kept hearing we shouldn't be a throw away society, but today it's the worst throw away society ever. Not much is made to be repaired anymore, just throw it away and buy more new junk. |
07-21-2018, 01:43 AM | #20 |
My grandfather used to manufacture the wooden plates that seperated the cells in batteries. I still have some of them. It has been interesting to hear my fathers stories about working in my grandfathers factory.
