06-27-2019, 12:22 AM | #1 |
29 cowl light questions
I am getting ready to install the cowl lights on a 29 Tudor. They were on the car when I received it for restoration and the customer wants to keep them on the car.
I bought new reflectors and pigtails. However, I am a bit confused about the fit of these parts. When I put them all together I noticed that the wire coming out of the bulb socket seems to be touching the retaining bracket and there is a screw that attaches to that bracket to hold the assembly into the housing/bucket--see photos. Is this a problem waiting to happen? I noticed on the original cowl lights that the brass socket fits much looser that the new parts and there seems to be two positions where I can click and lock the brass socket into the reflector socket. By pushing the brass socket further into the reflector socket I can have more space between the wire and the retaining bracket. Is the second position the correct position or just a better position. I don't like the idea of that screw shorting out the wire that goes to the bulb. What are your thoughts?
Why is there never enough time to do it right, but always enough time to do it over!!! |
06-27-2019, 08:46 AM | #2 |
Re: 29 cowl light questions
The rearward position will definitely be a problem. Go with the forward position, provided the bulb fits behind the lens. Looks like it would.
06-27-2019, 08:06 PM | #3 |
