Old 06-23-2019, 08:04 AM   #1
Ed in Maine
Default Purchasing a Model A Jack
I have been looking at Model A Jacks and have tentatively picked the "C1" version. This is the jack with three oval holes in the cast stand with a top that has been crimped over a lower piece. I want to be able to open up the top of the jack for cleaning, repair if necessary and grease and reassemble. Has anyone restored the "C1" jack and how difficult was it to open the top of the jack? Thank you, Ed
Ed in Maine is offline   Reply With Quote
Old 06-23-2019, 09:11 AM   #2
Gary WA
Gary WA's Avatar
Default Re: Purchasing a Model A Jack
http://www.donturley.com/Original_Tools.html
www.whidbeymodelaclub.com
Old 06-23-2019, 10:23 AM   #3
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Originally Posted by Gary WA View Post
Yes, Don or Gary Johnson are the go-to guys that are both very knowledgeable. Give either or both a call as they are very personable.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 06-29-2019, 07:05 PM   #4
alexiskai
alexiskai's Avatar
Looks like somebody's selling one:
https://www.fordbarn.com/forum/showpost.php?p=1772544
Old 06-29-2019, 09:30 PM   #5
Don Turley
Don Turley's Avatar
It was never designed and manufactured to be opened. Most everyone who buys an original Model "A" jack wants to use it in a display of original tools for their vehicle. That being the case, then clean it, paint it and put it in your tool display. The ones that I restore for cars being judged, I bead-blast every part that can be exposed then thoroughly blow out every bit of the grit that I can. I repair the slotted hole where the handle is inserted. Then I mask the screw and paint the rest with satin black paint. When the paint is completely dry, I put some oil on the screw, wipe off any excess oil and lower the screw to the closed position. It is then ready to display.
If you want a jack to raise and lower your "A", then buy a bottle jack at your favorite local auto supply store. They cost a lot less than an original Model "A" jack, work better and are safer. Just for the record, I would never put one of the ratchet style jacks under a car. Most of them are prone to failure and should only be used in a display. The screw style jacks are a little better than the ratchet style, but still questionable.
Don Turley is offline   Reply With Quote
Thread Tools
Display Modes
