08-15-2018, 09:57 PM | #21 | |
Re: Head Gasket repair 1936 21 stud
Always hand check it. |
08-15-2018, 11:10 PM | #22 |
Yes, will definitely check piston to valve clearance. I’ve been reading about guys using small balls of tinfoil to measure this.
-Troy Zephaniah 3:17 |
08-16-2018, 07:19 AM | #23 |
There is no piston to valve clearance on a flathead, believe you are referring to piston to head clearance & valve to head clearance.
08-16-2018, 07:27 AM | #24 |
Ha! You would be correct.. My past small block Chevy way of thinking is apparent with that statement.
08-16-2018, 07:45 AM | #25 | |
As for cleaning the block, the rear lower corners will be FILLED with crud. We re-did the engine on the '35, and I used a powerful pressure washer to blast it out. Was AMAZED at how much stuff was buried down in there! Good Luck
Mike Jr. here. I get on here every few months to check messages, and look through his almost 500 saved messages for information on the '29 and '34 I still have. A lot of very nice people on here. He truly enjoyed Ford Barn. |
08-16-2018, 08:24 AM | #26 |
08-16-2018, 08:35 AM | #27 |
Need to scrap around in there as well, there is wire and casting sand that needs to be nocked loose.
08-16-2018, 10:59 AM | #28 |
Yes, did that first with a coat hanger; scraped, scraped and kept on scraping..
08-16-2018, 07:23 PM | #29 | |
08-16-2018, 09:33 PM | #30 |
An additional thread concerning piston to head clearance. I see you are already there but for others it might be a good read.
https://www.fordbarn.com/forum/showthread.php?t=249194 |
