Old 11-19-2019, 02:52 AM   #1
Graham Freeman
Default 33/34 Cabriolet Question.
Just a minor question here.
Putting the windows back inside the cabriolet doors at present and am not sure what the fixing is at the top of the front door channel that screws thru the top of the door jamb.
Was it just a bolt or a flat head screw.
Obviously not a countersunk screw as there is no provision for the countersunk head.
Anyone out there with an original cabriolet that could have a look for me
Thanks Graham.
Graham Freeman is offline   Reply With Quote
Old 11-20-2019, 03:07 PM   #2
Graham Freeman
Default Re: 33/34 Cabriolet Question.
Any assistance here?
Old 11-20-2019, 03:55 PM   #3
David J
David J's Avatar
Front and rear are both slotted .
Front is flat and rear is countersunk on the engagement side .
Front one is flat on the exposed surface and rear is domed .
I can take pics if needed but the doors are kinda buried in the corner .
You do have the spring loaded tracks ?
Should be .
David J is offline   Reply With Quote
Old 11-20-2019, 06:55 PM   #4
Graham Freeman
Thanks for that David.
Exactly the information i was looking for and confirms what i thought was the way things went.
Yes i have the spring loaded tracks.
Graham
