08-26-2019, 05:54 AM | #1 |
Is There Any Epoxy That Will Stick To Brass???
I need to repair a small dent in a radiator top tank neck where the cap seats. It is leaking there and I added a recovery tank that will not return the excess coolant due to this dent. Will JB Weld or some other product stick to the brass so I can flat file the repair? This is a 1935 pickup so the cap does not have the typical gasket.
08-26-2019, 05:56 AM | #2 |
Re: Is There Any Epoxy That Will Stick To Brass???
Solder and file it off
08-26-2019, 06:49 AM | #3 |
I can't do that with the radiator installed in the pickup. I was hoping for an easier solution.
08-26-2019, 06:59 AM | #4 |
Do you have a junk radiator or something else that’s made of brass that you can try it on? I can’t imagine J-B Weld not sticking to brass......Mark
08-26-2019, 07:06 AM | #5 |
Any metal that oxidize is sensitive to time between tht you clean the surface with an abrasive and aplying the glue...
The faster you are the better chance to make it stick. |
08-26-2019, 07:16 AM | #6 |
08-26-2019, 08:06 AM | #7 |
Three yrs ago nice hot day for a beer run in my 1923 Ford, almost there, on these
the drain tube is on the bottom of the tank. Well this tube came undone from the bottom of the radiator and the fan grabbed it and yanked it out. Now stuck. so I called the wife for water. I carry wooden matches to light my cowl lights. I broke some matches up and shoved them in the tube holes. By then she showed up filled up with water and like a wooden boat they swelled up. Made my trip. made short took radiator out tried to soldering, no luck no room so hardward store 5 min. epoxie. 3 yrs no leaks...... |
08-26-2019, 08:33 AM | #8 | |
Big Job, your "secret weapon" like mine is "called wife for......what's needed now!" |
08-26-2019, 10:05 AM | #9 |
I've just used a two part epoxy product called 1212 made by Belzona. It's not cheap, $150 for 450g, but used it to repair a rot hole in a water jacket on a machined block.
So far so good. The reason we chose it was it able to be used on surfaces that are contaminated. |
08-26-2019, 10:13 AM | #10 |
I patched a dent/crack in the top tank of my International truck last year with JBweld. It stuck fine but not sure if I got perfect coverage as I still slight dampness around the patch.
https://www.youtube.com/user/roosty6/videos |
08-26-2019, 10:59 AM | #11 |
Check this Hudson from H.A.M.B.
Hold on, trying to attach picture of top tank repair with JB weld. Until I get it right, should also mention, JB makes a product in a stick, called Wet Weld.Screenshot 2019-08-26 at 11.49.14 AM.jpg
Enjoy yer day. Tom Hate can't fix what it started. Last edited by A bones; 08-26-2019 at 11:07 AM. Reason: failed attachment |
08-26-2019, 01:56 PM | #12 |
I soldered this brass union in to the top tank of my radiator whilst in situ?
Can you load a photo of your proposed repair ? |
08-26-2019, 10:51 PM | #13 |
How are things in situ nowadays ?
08-27-2019, 12:58 AM | #14 |
I had a 59 block that I pressure tested,
It was leaking from the pan rail in the left rear, I picked at it and it was a sure enough rust hole about 1/2” diameter. I drilled it out to 3/8 pipe size, tapped it and JB welded a brass plug in it. Filed it flat for the pan gasket and it’s still going strong today, no leaks. |
08-27-2019, 02:25 AM | #15 |
I don't understand. If you think you can use a filler of some kind to fill the dent and then flat file the repair with the radiator installed in the pickup, why can't you do the same with solder? As 'skidmarks' implied above, solder would be the best repair. I think solder would be easier to file as well. Show us some pictures....
08-27-2019, 04:24 AM | #16 |
Pete....Chuck is reluctant to solder in situ for fear of causing a fire or scorching adjoining areas...pic please Chuck !
08-27-2019, 05:52 AM | #17 |
I have now made the repair with JB Weld and will try to file it this afternoon. I never did figure out how to post photos on the site. The radiator shell is almost touching the neck so I can not use heat there.
Chuck |
08-27-2019, 08:25 AM | #18 |
If you want any photos posted you can email them to me to post.
08-27-2019, 01:04 PM | #19 | |
It was my thought that he would use a heavy duty soldering iron as opposed to a torch....
08-28-2019, 03:29 PM | #20 |
Loctite EA-120HP HYSOL part no. 29353
