06-09-2019, 04:30 AM | #1 |
1965 comet 289
I have A 65 comet caliente ,with A tremac 5 speed , needs A new engine , undecided, to rebuild the 289, or go for A 302 , If I go for A 302 what problems will I have with the install ?
06-09-2019, 05:53 AM | #2 |
Re: 1965 comet 289
Talk about a beautiful body style ...
First, how fast do you want to go and how much $$$ do you have to throw at it?
***** - WHY IS IT ... - ... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag? WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order) Last edited by KULTULZ; 06-09-2019 at 06:25 AM. Reason: ADD EYE CANDY |
06-09-2019, 06:19 AM | #3 |
Re: 1965 comet 289
It should be a direct bolt in, unless your 289 is the early one with the 5 bolt bell pattern.
06-10-2019, 10:27 AM | #4 |
Re: 1965 comet 289
I believe if you go newer than 1973 block there is no clutch cross shaft hole in the block. The casting may be able to be drilled but when they went to lighter blocks in 80 that part of the casting was eliminated. Someone made at one time a bracket that bolted to the bellhousing bolts and would accept the ball stud. I tried to use a mid 80's 302 in a 68 Torino with column shift automatic and it need that same hole in the block on the linkage. Just ended up rebuilding original rather than cobble as it wasn't my car. Another roadblock on that swap was the switch Ford did to the 50 ounce imbalance. flex plate I could handle but harmonic damper was different and they had moved timing marks so it needed another front cover but the Torino had passenger side lower radiator hose like older mustangs so it would have meant swapping all the front of the engine and radiator. At the time someone made a special balancer for the early Mustang guys doing the late model swap but didn't know if it would work for me. I always thought the 289's ran better than the 302's in my day. But the emissions controls and lower compression started about the same time 302's came out. I did rebuild a 91 Mustang GT and it was a good performing car.
06-10-2019, 08:49 PM | #5 | |
Re: 1965 comet 289
This piece should be available. Try the Fairlane parts suppliers. I had to get one when I put a late model 302 in a 64 Fairlane.
06-11-2019, 08:13 PM | #6 |
Re: 1965 comet 289
08-07-2019, 11:10 AM | #7 |
Re: 1965 comet 289
Installed the 302 ,so far good ,more torque and hp then the 289 , engine was dyno, readings were 335 ft lbs of torque, and 249 hp, looks good and runs nice , blueprint from summit, 30,000 mile or 5 year warranty.
08-07-2019, 01:09 PM | #8 |
Re: 1965 comet 289
Nice ! sounds like your a happy camper. Thanks for posting the results.
Sal |
