04-18-2017, 01:35 PM | #1 |
Pinion Nut
The 52 Merc has had a loose pinion and leaking seal ever since I got it mobile so today I finally got around to looking at it. I found the nut holding the yoke onto the pinion shaft was not very tight. I must have tightened it quite a bit and now the shaft is noticeably tighter fitting. Before I could literally move the shaft up and down inside the seal area. No movement now. No doubt it still needs a seal. I guess it is time for a test drive.
https://www.youtube.com/user/roosty6/videos |
04-18-2017, 01:48 PM | #2 |
Re: Pinion Nut
It will surely need a seal,,,,drain it and see how much bearing comes out..
04-18-2017, 01:55 PM | #3 |
Re: Pinion Nut
I doubt there is any bearing damage yet. It runs fine but had a bit of a howl on deceleration.
04-18-2017, 02:37 PM | #4 |
Re: Pinion Nut
Should have a new crush sleeve before tightening pinion nut to the specified torque value which sets the preload on the bearings.
04-18-2017, 05:32 PM | #5 |
Re: Pinion Nut
...Terry Last edited by Overkill-F1; 04-18-2017 at 05:41 PM. |
Thread Tools | |
Display Modes | |
