Old 03-16-2018, 07:11 PM   #1
JohnB15632
JohnB15632's Avatar
Default 31 Floor Cover Over the Rear Spring
When it comes to installing the cover over the rear spring that sticks up through the floor, how tightly is the cover pulled taunt over the spring?
Is it possible that the rear spring might raise up farther?
Thanks for the help.
JohnB15632 is offline   Reply With Quote
Old 03-16-2018, 10:27 PM   #2
jetmek
Default Re: 31 Floor Cover Over the Rear Spring
Mine is made from scrap seat upholstery and top material it has loops sewn for the metal straps and sewn together from the corners to make a tent shape if I recall. not really tight over the crossmember.Ill pull the seat out and check it when im looking at the armrest for you...
engine and component overhauls my specialty!
Website- www.godevilgarage.com
jetmek is offline   Reply With Quote
Old 03-16-2018, 10:37 PM   #3
Bob Bidonde
Bob Bidonde's Avatar
That is the frame's rear crossmember that protrudes into the car and the body is attached to the frame so no additional protrusion will occur.
Bob Bidonde
Old 03-16-2018, 11:17 PM   #4
pbishop
Bob is right, as the bump is part of the frame it cannot rise any higher than it already is.
pbishop is offline   Reply With Quote
Old 03-17-2018, 05:25 AM   #5
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
SO, it is mainly to keep out SOME noise & COLD air????
Bill W.
"THE ASSISTANT GURU OF STUFF"
BILL WILLIAMSON is online now   Reply With Quote
Thread Tools
Display Modes
