Old 03-16-2018, 09:54 AM   #1
HOTRODPRIMER
HOTRODPRIMER's Avatar
Default Just what is the difference in the "A" & "B" 4 cylinder Ford engine?
Being new to original 4 cylinder Ford engines and trying to educate myself share with me what you have learned over the years.
This is my introduction to the 4 in a row. HRP
‘When one door closes, another opens. But we often look so regretfully upon the closed door that we don’t see the one which has opened for us.’ Alexander Graham Bell
HOTRODPRIMER is offline   Reply With Quote
Old 03-16-2018, 10:22 AM   #2
johnneilson
Default Re: Just what is the difference in the "A" & "B" 4 cylinder Ford engine?
HRP,
the best advise I can give you is to read and think thru what you will hear.
in a nut shell, "B" motor has larger journals in rotating assembly than the "A".
Fuel pump added, cam marginally better, chamber difference in head are just some details.
Both models are prone to cracking if not properly cared for.
John
As Carroll Smith wrote; All Failures are Human in Origin.
johnneilson is offline   Reply With Quote
Old 03-16-2018, 10:31 AM   #3
Bob C
Go to Vince's site and scroll down to Engine Mechanical Assembly, a
lot of information on the two engines. http://www.fordgarage.com/
Bob
Old 03-16-2018, 01:04 PM   #4
Jim Brierley
25% more horsepower in the B.
Old 03-16-2018, 01:38 PM   #5
hardtimes
hardtimes's Avatar
Ford built the B to improve on the A. Just like Ford built the flathead V8 to improve. Easy to digest, eh ?
So, logically the B is a better engine for reasons stated. More reasons added, is that Ford added better oiling to B for mains. Ford also added a fuel pump with improved performance under most conditions.
Going from a '32 B engine in you '32 car , to an A engine would be regressive, IMO, unless you got a hot A engine over a stock B engine.
Oh, and red paint adds mph and hp to both A/B !!
Old 03-16-2018, 06:52 PM   #6
daren007
The fuel pump was required because the fuel tank was relocated to the rear of the car.
daren007 is offline   Reply With Quote
Old 03-16-2018, 08:42 PM   #7
Tom Wesenberg
Tom Wesenberg's Avatar
Your lower water pipe needs to be turned end for end.
Old 03-16-2018, 09:34 PM   #8
HOTRODPRIMER
Can you elaborate? HRP
Old 03-17-2018, 01:03 AM   #9
Tom Wesenberg
Loosen the two clamps, remove the steel pipe and turn it end for end. It's installed backwards now. It'll fit better, and the drain cock will be at the lowest spot.
OK, I was just informed you have a 32, not a Model A, so this pipe isn't correct for your car, and the 32 pipe isn't reproduced. Vince has the correct pipe though.
Here's a like to Vince Falter's website.
Old 03-17-2018, 03:32 AM   #10
Randy in ca
Randy in ca's Avatar
Normally what Tom initially said above would be correct, except that it appears that your's has been modified for a heater hose. What does the other side of the engine look like? Definitely not stock carburetor. Also noticed that your vibration damper is not attached to the rear of engine.
Randy in ca is offline   Reply With Quote
Old 03-17-2018, 05:20 AM   #11
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
What is this, so called, "vibration dampener"????
Bill Neverheardofit
"THE ASSISTANT GURU OF STUFF"
BILL WILLIAMSON is online now   Reply With Quote
Old 03-17-2018, 08:11 AM   #12
daren007
Looks attached to me.
Old 03-17-2018, 11:15 AM   #13
Bob C
The whole arm is missing between the stabilizer and the engine.
Bob
Old 03-17-2018, 01:20 PM   #14
hardtimes
hardtimes's Avatar
Bill Neverheardofit
Hey Bill,
If you look closely...as old eyes like mine can't do, you will notice that that is not a model a firewall (IMV).
Ford , most likely, thought that the '32 engine would 'feel' like it was operating more smoothly , if it was not transmitting engine vibes thru the frame / vehicle...ergo he added (on firewall) vibration dampener. Someone more familiar and/or owning a '32 car can correct or add to this info if necessary, as I'm not in the class ($ wise) to own a '32, but like many admire Fords change of styling from that of Model A.
BTW...that's if behind the red colored coil cover.
Also, evidently, pic shows 3 bolt waterpump B head, but I'm not convinced that this is not an A block. That does not look like a B oil tube(?). HRP...show other side of block. I think that it is A blk shown (in a '32) and that is why he is asking about A vs B question..no ??
Old 03-17-2018, 03:19 PM   #15
Randy in ca
Should post this on the Early V8 (1932 to 1953) forum also - there's several experts on the Model B 4 cylinder engines and the differences there.
Old 03-17-2018, 07:13 PM   #16
daren007
There appears to be a bracket from the dampener to the top two bell housing bolts as far as I can tell. The breather is a model B.
Old 03-17-2018, 08:00 PM   #17
Bob C
Are you looking at the red engine??
Old 03-17-2018, 09:23 PM   #18
daren007
Sorry. The other one.
