Old 02-16-2020, 11:19 AM   #21
Bob C
Default Re: So when would my car actually have been made?
I think one of the only differences between a late 1930 and an early 1931
pickup would be the Ford emblem on the radiator shell.
Old 02-16-2020, 02:12 PM   #22
Charlie Stephens
My older copy of the Judging Standards says "may be as long as three months after the engine was produced...". Depend on where the vehicle was assembled it could have been a couple of days.
Charlie Stephens
Old 02-16-2020, 02:54 PM   #23
Steve Plucker
Charlie Stephens
Or the same day.
Old 02-16-2020, 04:47 PM   #24
John Dayhuff
John Dayhuff's Avatar
Hmmm...not sure I'd want to attempt to take the body off, I mean I want to know but proabally not that badly and I'd be afraid of screwing it up but thanks for insight as to how it could be done, I appreciate that.
The Speedometer is oval and odometer hasn't worked in over 50 years so the title says N/A for mileage...LOL.
John
John Dayhuff is offline   Reply With Quote
Old 02-16-2020, 07:19 PM   #25
Bob C
The oval speedometer would mean it was built before June 1930.
Bob
Old 02-17-2020, 04:57 PM   #26
John Dayhuff
Wow, ok. That's good to know. Anything else that is extremely obvious that help date it?
John
John
Old 02-17-2020, 08:57 PM   #27
Bob C
John
You need a copy of the Judging Standards, you'll probably find quite a few things you can check.
Old 02-17-2020, 11:39 PM   #28
Tudortomnz
Tudortomnz's Avatar
Originally Posted by whirnot View Post
So here is a question I have posed several times. My pickup is a Dec 30 according to the frame number. If the engine was built and stamped in Dec 30 and it took three months to get installed and the frame stamped. It would have been March of 31 before it was built.
It has all the characteristics of a 30 but I still wonder about that scenario.
Do you think Ford threw all the '30 inventory away & only used latest production items on 1/1/31? That was not how the model changes occurred in that era. The s/s '30 shells would have been used up into early '31 etc plus 3 month time spans before engine use could have been shorter or longer depending on production volumes at any particular plant.
Tudortomnz is offline   Reply With Quote
Old 02-18-2020, 01:02 AM   #29
gnolnor
gnolnor's Avatar
Henry Ford did not throw anything away! As I understand the assembly line, parts were not stored. His plant was frugal! He required that parts from suppliers be delivered on oak pallets, so body wood parts could be made from the oak wood. He did not have to buy the oak wood!
gnolnor is offline   Reply With Quote
Old 02-18-2020, 01:51 PM   #30
rotorwrench
rotorwrench's Avatar
The 1928 and 1929 cars have a different front cross member from the 1930/31 frames. The 1930/31 models have a lower mounting area for the radiator than the 28/29 due to the difference in height. The later frame radiator pads are slightly lower or depressed into the member where the 28/29 member is raised up a good bit.
This is a way you can check the frame for 28/29 characteristics that are more obvious. Now a cross member is replaceable but riveting them is complicated. Folks in the shade tree classification usually used bolts instead of rivets it they were replaced. If yours has 1930 or later characteristics then it will likely not match the engine number.
Folks that restored or maintained these cars in earlier eras may not have has such complicated rules involved with titles and registration as we have in this day and age.
