Old 10-28-2019, 09:11 AM   #1
jwilliams81
jwilliams81's Avatar
Default Great experience with Schwalm's!
I am so pleased with my engine and transmission rebuild from Schwalm's. My engine was picked up by a shipper on September 9. It took two days to get there and I just received my rebuilt engine with new Babbitt and transmission on October 25th.
Talk about turn around, 32 business days!
Here is everything I had done:
  • Rebuild Model A Long Block (1931)
  • New 5.5:1 Cylinder Head
  • Balance Engine Components - Crank, Rods, Pistons
  • Counterbalanced Crankshaft
  • Performance Intake Valves
  • Type 1 Lightened Flywheel/V8 Pressure Plate
  • New Clutch Disc
  • New Camshaft
  • Install Cam Bearings
  • Machine for Oversize Tappets
  • Resurface Manifold Side of Block
  • Water Pump
  • Transmission Gear Box Rebuild
  • Shifter Tower
  • Bell Housing/Peddles
  • Seal Shifter Shafts
  • Bell Housing Bolts
  • Helicoils in 5 head studs
They kept me up-to-date through emails and phone calls. Excellent service.
I am beyond excited to try starting her up later this week once I get it installed.
EDIT: Added to original post to make it easier to find:
I was able to get everything put back together after work last night. Here is the video of the first start!https://www.youtube.com/watch?v=2EpN3lda_L8&t=1s
1931 Murray Town Sedan. Black body with Apple Green pin stripe.
1923 Model T Touring with electric start. Low radiator
Cincinnati, Ohio
jwilliams81 is offline   Reply With Quote
Old 10-28-2019, 09:43 AM   #2
Bob Bidonde
Bob Bidonde's Avatar
Default Re: Great experience with Schwalm's!
Nice. The engine in my 190A was done at Schwalm's and it is performing very well.
Bob Bidonde
Old 10-28-2019, 10:12 AM   #3
jwilliams81
That's great to hear. Their reputation was one of the main reasons I choose them.
Cincinnati, Ohio
Old 10-28-2019, 10:47 AM   #4
fried okra
Location: Daniel Island,SouthCarolina/Knoxville, Tennessee/Sanibel Island,Florida
Looks real nice!
Painted in Model A Ford engine green I trust?
Just hard to tell from the pic, seems to maybe look a little darker in the photo to me.
thanks,
fried okra
fried okra is offline   Reply With Quote
Old 10-28-2019, 10:54 AM   #5
jwilliams81
Yes sir, the correct green for most of the engine. Pan, throttle linkage, and oil tube are black.
Originally Posted by fried okra View Post
Looks real nice!
thanks,
fried okra
Cincinnati, Ohio
Old 10-28-2019, 11:28 AM   #6
fried okra
Great, I figgered so
fried okra
Old 10-28-2019, 11:45 AM   #7
1929
My engine was done by Scwhalms too.
1929 is offline   Reply With Quote
Old 10-28-2019, 01:02 PM   #8
chrs1961815
chrs1961815's Avatar
Just out of curiosity how much did you pay for all of that?
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 10-28-2019, 01:39 PM   #9
jwilliams81
Short answer, the prices are on their website listed in my original post.
Long answer, I saved for an entire year. But this should last me well into my 60-70's. I am 38 now
Cincinnati, Ohio
Old 10-28-2019, 05:12 PM   #10
Conaway2
Conaway2's Avatar
I installed an engine (short block) and V8 flywheel/clutch rebuilt by Schwalm’s in March. The engine runs beautifully and I would use them again !
Conaway2 is offline   Reply With Quote
Old 10-28-2019, 10:01 PM   #11
Jeff/Illinois
Jeff/Illinois's Avatar
That is a wise move, spend your money up-front for quality and forget it!
And again, thanks for posting your positive review. It is refreshing to hear something good and not somebody bitching because of this or that, and often times only hearing part of that story to boot!
Old 10-29-2019, 08:00 AM   #12
37 Coupe
37 Coupe's Avatar
Has this been done or will any of the engine builders machine and restamp serial number area?
"Never complain,never explain"... Henry Ford II
37 Coupe is offline   Reply With Quote
Old 10-29-2019, 08:20 AM   #13
M2M
M2M's Avatar
Nice $10K engine
M2M is offline   Reply With Quote
Old 10-29-2019, 08:49 AM   #14
jwilliams81
Not sure what you mean. I pulled the engine from my car, built a crate, sent the engine to Schwalm's rebuilt it, and sent it back to my in the same crate. There is no need to restamp the serial number.
Cincinnati, Ohio
Old 10-29-2019, 11:37 AM   #15
37 Coupe
37 Coupe's Avatar
There is if you want it to match the title like mine. My original went for a Sears core charge 50 years ago,Not one of Henry'
s better ideas especially with an engine trade in plan.
Old 10-29-2019, 12:00 PM   #16
ronn
37 easier to change the title or restamp
Old 10-29-2019, 02:32 PM   #17
37 Coupe
37 Coupe's Avatar
Nothing is ever easier at the DMV in Ohio at least my local one. I had enough trouble registering this car a year ago not because of the serial number but the previous title. The man who owned my '31 roadster for over 50 years was also a use car salesman in Toledo Ohio and the title of all his collector cars were under his dealership or car lot name.So DMV tells me that previous title /car lot was no longer a registered dealer.DUH says I the guy would be over a 100 years old,the son I bought it from was 80.So they tell me I have to take it to court and pluck down 400 dollars to get the court thing going. Finally the more knowledgeable DMV person tells us the title was old enough to be grandfathered in before the requirement under car lot transfers. I would not want to question the serial number even further. I once had a 1939 Ford convertible and the previous title showed it as a Tudor,I asked for the gal to type mine in as a convertible coupe and she stopped dead in her tracks and asked me if I was trying to get her to creat an illegal title and should she get a legal person to question me.So title remained Tudor as will my title with Model A engine that is not a '31 but a '29 or '30.
Old 10-30-2019, 07:49 AM   #18
jwilliams81
Cincinnati, Ohio
Old 10-30-2019, 08:09 AM   #19
wmws
Nice to see a young fella so enthusiastic about his A. Engine sounds great as all Schwalms engines do.
wmws is offline   Reply With Quote
Old 10-30-2019, 08:18 AM   #20
ronn
guess its all about who you know then. Have friends in OH and never a problem...........
