Old 09-25-2018, 06:54 PM   #1
unclesam
Question shattering clutch, i need a fix
i have owned four model a's and all had a shattering clutch!!!, how do i smooth out a clutch in a model a?????
unclesam is offline   Reply With Quote
Old 09-25-2018, 07:51 PM   #2
KR500
KR500's Avatar
Default Re: shattering clutch, i need a fix
Get the flywheel and pressure plate and clutch disc balanced as a unit.
KR500 is offline   Reply With Quote
Old 09-26-2018, 05:34 AM   #3
Patrick L.
Patrick L.'s Avatar
Shattering clutch ? I'm thinking you're talking about a chatter/shake.
That is usually caused by improper bell housing alignment and pressure plate finger adjustment. It could also be caused by a warped flywheel.
Old 09-26-2018, 10:17 AM   #4
Dick Steinkamp
Dick Steinkamp's Avatar
There is no way to balance the clutch disc as part of the rotating assembly since it ends up in a different spot every time you use it.
In addition to other thoughts, could be grease or oil on the clutch disc.
All steel from pedal to wheel
Dick Steinkamp is offline   Reply With Quote
Old 09-26-2018, 11:30 AM   #5
ryanheacox
ryanheacox's Avatar
That was my problem. Rode the clutch as I drove it for a little while and it cleared itself up.
ryanheacox is offline   Reply With Quote
Old 09-26-2018, 12:13 PM   #6
john in illinois
john in illinois's Avatar
Worn motor mounts can cause chatter.
John
john in illinois is online now   Reply With Quote
Old 09-26-2018, 04:31 PM   #7
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Try doing SMOOTH second gear only take offs, for a MONTH. Just slowly let out the clutch ALL the way, at an idle & then give it the GAS.----That smoothed out Minervas' clutch beautifully!
Let me know if that worked & I'll explain WHY.
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 09-26-2018, 05:20 PM   #8
Big hammer
Mine was so bad it shuck rust and dirt for under the body :-( When I was repairing the car I checked the flywheel, pressure plate, and disc. Sanded the flywheel face, sanded the pressure plate, and bead blasted the disc. In testing after repairs where done the clutch was smooth as silk :-)
get a bigger hammer tap done
Old 09-26-2018, 07:27 PM   #9
unclesam
i assume you would balance to "0"?????
Old 09-26-2018, 07:31 PM   #10
unclesam
can you suggest a book that would walk a guy thru this???, is it a special machine/ procedure to clean up a flywheel or can i do it on a lathe???
Old 09-26-2018, 07:32 PM   #11
unclesam
worth a try before i tear it apart
Old 09-26-2018, 07:34 PM   #12
unclesam
i will try it, is that once a day for a month or ten times a day???
Old 09-26-2018, 09:24 PM   #13
Tom Wesenberg
Tom Wesenberg's Avatar
My 29 vibrated like a paint shaker, every time I started from a dead stop. I installed a new disc, a good looking used pressure plate, and dialed in the flywheel cover. I also used my 1/4 sheet electric sander to lightly sand the flywheel face. Now it's smooth as an automatic.
Old 09-26-2018, 10:00 PM   #14
BILL WILLIAMSON
OK, I'll explain the "WHY" on post#7---Model As are commonly prone to clutch chatter on initial take off. Each time it chatters, it creates HIGHS & LOWS in the disc lining. Each time it does it, they get HIGHER & LOWER.
The idling second gear take off uses ONLY the HIGH spots for grip. SO, in time, they wear down to the same level as the LOW spots & it doesn't chatter any more.
HOPE THIS MAKES SENSE TO YOU, IT'S THE BEST I CAN EXPLAIN IT!
Bill W.
Thread Tools
Display Modes
