11-05-2017, 01:07 PM | #1 |
Tie Rod - Original vs. Repro
The new tie rods sold by the vendors are solid whereas the originals are hollow with plugged ends.
Which is stronger/better for a tie rod? |
11-05-2017, 01:22 PM | #2 |
Re: Tie Rod - Original vs. Repro
I don't think it makes much of a difference. With today's much nicer roads (streets really), model A's have a much easier life than in the 30's, 40's and 50's. Bending a 5/8" solid repro rod isn't easy.
Rusty Nelson |
11-05-2017, 01:33 PM | #3 |
For as many hollow tie rods that were made I would not believe there was a safety issue with them, the new rods would be already to paint and install, pick a vender close to you and save the shipping.
Nothing can be made foolproof, ---- fools are ingenious bastards. |
11-05-2017, 08:21 PM | #4 |
Hollow is stronger.
11-05-2017, 08:39 PM | #5 |
I thought it would be the opposite.
11-06-2017, 09:08 AM | #6 |
Well Yes & No. Define stronger in which direction. If you are saying linear pulling, the rod is stronger. If you are comparing bending, the outer mass on both equal the rod and the tube is what resists the bending motion. The way to say this is, when a Hollow tube and a Solid rod of the same mass are compared, the hollow will be stronger. |
11-06-2017, 09:22 AM | #7 |
Brent,
How can a hollow rod and a solid rod be the same mass, unless the hollow rod is much larger? Solid and hollow tierods are the same size, so does than mean the solid rod is stronger? Rusty Nelson |
11-06-2017, 09:25 AM | #8 | |
11-06-2017, 09:37 AM | #9 |
I'm not an engineer but I think it would work like this, if I can articulate my thinking. Think of the bends in the thin sheet metal used on cars today, the bedside of a pickup truck. Bends are made to add strength. With a hollow tube unless it's struck with something to cause the bend it has two more surface areas than a solid rod to be bent.
I may be off on my thinking but I think I'm close. With trees there is a compression side and a tension side and one has to fail before the other will. Not sure I explained what's in my mind. History, uneducated Sorry Bill I had to steal that. |
11-06-2017, 09:47 AM | #10 |
Why more questions need to asked beyond bending. I will say I do not have the answers to any of the below questions.
What metals are involved? How well are the threads formed that hold the ends? What metal is used on the threaded ends? How well is it welded? There are enough good originals out there. My choice is always going to be to locate a good original. They hold up well and never had issues with stripping out. Which brings me to my neighbors across the street with their fairly new (at the time) Saturn car. The factory tie rod end stripped out of the socket while driving. So is newer better? |
11-06-2017, 10:11 AM | #11 |
just to throw a stick in the wheel the AA tie rods used the same tierod ends as the standard A but the rod itself is fatter and hollow in the middle for added strength
DSC04122 by Bob Bobbington, on Flickr DSC04121 by Bob Bobbington, on Flickr
1929 Model AA - Need long splash aprons! |
11-06-2017, 10:47 AM | #12 |
Take it from a mechanical engineer, if the material and outer diameter are identical, a solid rod will be stronger in both tension/compression and bending than a hollow rod, end of story. Don't make me break out the math!
11-06-2017, 11:22 AM | #13 |
This should settle it once and for all, ...
https://physics.stackexchange.com/qu...e-diameter-o-d Regards Bill |
11-06-2017, 11:31 AM | #14 |
The Original Hollow ones will bend easily compared to a solid one.
"If I asked people what they wanted they would have said faster horses." -Henry Ford "Primitive technology is not a design flaw" 1928 Ford Model A Roadster Pickup 1930 Gordon Smith Air Compressor 1941 Willy's Pickup 1960 Thunderbird-For Sale 1964 Buick Riviera 2x4 425 1965 Pontiac GTO, 455 Super Duty 2004 Dodge Ram SRT-10, V-10 Viper 1977 Charger Jet Boat,460 Ford,Jacuzzi Jet Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford Engine Build up on DVD ask |
11-06-2017, 12:01 PM | #15 | |
11-06-2017, 12:14 PM | #16 |
I agree with Sparky. Like I mentioned before in this string, I really don't think it matters whether the tie rod is hollow (original) or solid (repro) - it is strong enough either way. I think Ford was trying to save some steel by making it hollow. I think we are getting bent around the axle, I mean "tie rod", so to speak.
Rusty Nelson |
11-06-2017, 07:30 PM | #17 | |
As some of the guys said I don't think it really matters for the average driver. Main thing is that it's straight and can rotate freely in the threads. The current repros from the key suppliers are just fine. All the best! Larry PS.. been gone but answered your pM. |
11-06-2017, 08:51 PM | #18 |
Mass has quality and metallurgy counts. The comparison should be based upon the relative strength of Ford's hollow tie rod versus a solid rod from Chairman Mao's backyard foundry.
11-06-2017, 09:06 PM | #19 |
OVERTHINKING, AGAIN, spare me, please!
Bill W.
11-06-2017, 09:26 PM | #20 |
Thread Tools | |
Display Modes | |
