10-16-2018, 06:32 PM | #1 |
Houdaille Shock
Picked up a set of houdaille shocks for 6$ a piece and am in the process of freeing them up. I am using MAPP gas to heat up the threads.
Is there a better tool to use to open grab on to the body than channel locks. Should i use a strap wrench?I got this far and gave up until i can order a deep impact socket. I believe a 40mm deep socket will fit the nut the best. are all the thread right hand? |
10-16-2018, 07:07 PM | #2 |
Re: Houdaille Shock
There are CW and CCW shocks and you do not want to mix parts. Disassemble each shock individually and keep all the parts for each shock in its own container so when you reassemble you keep the correct parts with the correct body.
1931 160B & 1931 68B If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time? |
10-16-2018, 11:42 PM | #3 |
Re: Houdaille Shock
10-17-2018, 05:42 AM | #4 |
Re: Houdaille Shock
"The emphasis on production probably explains why the endemic leaks were never fixed, why steel-on-steel rotor bushings continued to be used, and why shocks were shipped with glycerin after hydraulic oils became available"
From: http://www.goldcoastmodela.com/Shocks/hhist.html Good luck. |
10-17-2018, 03:36 PM | #5 |
Re: Houdaille Shock
You are going to need a lot more leverage than a pair of channel locks. I use a 36" pipe wrench with a persuader extension and a lot of heat. some guys bury them in the charcoal of a weber grill to get them red hot.
It takes a lot of leverage to break them. |
10-17-2018, 07:21 PM | #6 | |
Re: Houdaille Shock
10-17-2018, 08:08 PM | #7 |
Re: Houdaille Shock
1932, without seeing the bottom of that shock. it appears to be a 32 shock. if so they do not work very well on a Model A they are to tall and hit the brake rods.
the Diablo A`s put out a DVD on how to rebuild Model A Shocks. and I will say it is pretty darn good. |
10-17-2018, 11:31 PM | #8 |
Re: Houdaille Shock
Here is a photo of the backs. The first shock in this photo doesn’t indicate manufacturer and has no lock ring. Were there multiple manufacturers or maybe this one is a reproduction shock .
10-17-2018, 11:48 PM | #9 |
Re: Houdaille Shock
I wish I had a mill, but I had to use a drill bit to rough out a hex, then used a milling bit in my drill press and slowly and carefully milled out the hex. I then put the drill press head at a slight angle to put the taper to the hex. After that hex fit the shock hex perfectly, I then welded the two long handles to the large round center part.
10-18-2018, 01:54 AM | #10 |
Re: Houdaille Shock
the first three of them are 1932`s the forth one is a Model A
