10-09-2018, 05:32 PM | #21 |
Re: Merc crank in a 24 stud pencil test block
I check the deck ports on those prewar engines. That is the best way to tell if they are a 221 or a 239. The 239 always has the round center ports. 221 engines are always keystone shaped.The 99A family of prewar engines is not as common in this day and age so most are likely 221. The pencil test just tells you whether it is prewar or not.
10-09-2018, 08:39 PM | #22 |
Well according to 42 merc, there were some exceptions.... I picked up my beautiful merc crank today at the quarry. Their diesel mechanic was on the mainland and had a pick up at Valley Machine so he brought it back to the island for me. .010 on the mains and .020 on the rods. I plan to use the insert type 8ba style rods. Today I looked up 'ultrasonic thickness tester' on ebay and amazon. Industry standard rig is about 1100.00, but a lot of testers out there from 65.00- 250.00 That claim to do what's needed. Anybody have experience with these?
10-09-2018, 11:05 PM | #23 |
The person who does all my flathead machining sonic tests the blocks and the minimum wall thickness he will build on is .100. The sonic testers need nothing on the inside as it is calibrated to a known thickness so you can test many places you couldn't get at with your calipers. I would think any shop that bores engines would be able to sonic test for you.
I have a NOS 41 Merc block which is 3 3/16" that passes the "pencil test" 99% of blocks that do pass this test started life as 221 3 1/16" bore blocks but exceptions do exist. Good luck |
10-10-2018, 10:12 AM | #24 |
I ordered an ultrasonic tester on amazon. Has 5 stars, if that means anything. I also read that you can test for accuracy by using it on something of known thickness or something you can easily mic. We'll see. I also re-inspected my stash of other blocks and find them to be in very good condition (visually), so we'll get that crank into something good. https://www.amazon.com/gp/product/B0...4JPBPJA54647YZ
10-20-2018, 09:16 AM | #25 |
My tester arrived, but the instruction booklet says that it's not recommended for cast iron due to its granular nature. I did however grind a flat area on both legs of my caliper. When its pointed tips are closed together, I set my digital slide caliper to zero and read the thickness of the bores in the negative scale. I get very consistent results and for the most part the thickness is right around .125 with small variations. Always thicker at the top.There is a place at the bottom of #1 cylinder at the front where the thickness is .075, but it gets thicker as it goes up. The rear side of that cylinder is thicker than the rest, suggesting the dreaded core shift. I suppose I will take it somewhere for a sonic test, but if my results are accurate, what to do? Meanwhile I have been thinking of using one of the other blocks. The blocks are stored on a concrete floor under a deep lumber rack and hard to see where they are. Yesterday I received two Jegs engine stands. 4 wheel type for 39.95. I was quite shocked at the good quality. At 1000 lb capacity, I plan to weld a 1/4" plate to the base to hold a 59 ab type block upside down and hang an 8ba endwise from the stand. 4 of these units will hold the 8 blocks up off the floor and easy rolling across the slab to my engine area. Question of the day, Is it ok to suspend an 8ba endwise for extended storage periods?
10-20-2018, 09:25 AM | #26 |
10-20-2018, 09:38 AM | #27 |
When the thickness is reduced too much there can be hot spots but they would tend to be closer to the top of the bores where the combustion takes place. If most of the measurements are over .100" then it may work OK. Corrosion can be the cause of thin spots as well as core shift.
10-20-2018, 10:23 AM | #28 |
I had also thought that most of the problems associated with a thin wall would be more of a problem higher up. I have been thinking of using something called 'Evans Coolant', which is some kind of oil with a very high boiling point. No cavitation or corrosion but $$. At least the wall wouldn't get thinner. Hmmm, I'm encouraged about that block.
10-20-2018, 10:36 AM | #29 |
Before you get enamored with Evans coolant, do a few searches on the various "old car" boards.
10-20-2018, 11:10 AM | #30 |
Given the testing you've been doing, I don't see a problem with the block - as long as you pressure test it before sinking a bunch of time and $$$ into it. Speedway has a pressure test "kit" that works well - given the number of blocks you have, it would be worth having. Here is my basic block selection/validation process:
1) Initially wire brush all the transfer areas between the valves and bores - then wipe everything off with a good solvent (like lacquer thinner). Do the same on the pan rails. Take a good magnifying glass and inspect these areas for cracks. 2) Have the "good blocks" hot-tanked (or baked/tumbled) and then magnafluxed - to validate that they are good blocks. If you can, it is always good to get as much casting flash and sand out of the block water jackets - can make a big difference in cooling. Consider using a de-rusting solution in the water jackets. 3) Then do a sonic test to validate cylinder wall thickness - I don't like to go below .100 on anything . . . and preferably .125 or thicker. I take the probe and measure 12 points on every cylinder - three locations up/down the bore and all four sides. Write everything down to document the results - may come in handy during the boring process (to "shift" a bore around a bit to account for core-shift). 4) Then pressure test the block to 40 - 50 PSI . . . to ensure you don't have any casting pin-holes or cracks up inside the exhaust ports. Now - I'm ready to go to work and do the necessary machine/rebuilding work . . . |
10-20-2018, 03:05 PM | #31 |
Lots of great advice here, and pressure testing seems highly worthwhile. Thanks! I found the speedway kit and it looks fine, but over the last year I have been thinking about building one and now that I see how simple their's is, this is what I may do. Call me a cheapskate, but I'm trying to get something put away for retirement.... Ok, I have a lot of 60 mil epdm rubber roofing left over from my woodie project. So I make a 'head gasket'. just the 24 holes on a rectangular piece. Then I use a head for the block off plate. This epdm is like a truck inner tube but flat. Next a couple of gutted water pumps (I have a crate of them). Somewhere I introduce a schrader valve. Pump it up, check with a good tire gauge. How about a section of old bicycle tube with it's valve intact, hose clamped to the water pump's neck ?..... BTW, I already assembled one engine stand this morning and welded a 20" piece of angle to the stock plate. The legs of the angle welded to the plate. 45 degrees with little effort and no math. My wife's at work and I told her I'd be painting the bathroom today. I better get going.
10-21-2018, 02:03 AM | #32 |
After I made the rubber "head gasket" piece and put the head on, I aired it up and after a while the rubber blew out at one of the water passages. I had some thin galvanized flashing, cut and drilled a piece just like the rubber. So new rubber, sheet metal, then the head. Holds pressure good.
10-21-2018, 07:33 AM | #33 |
10-21-2018, 08:00 AM | #34 |
Using a cylinder head to provide closure on the deck will allow a leak test but it hampers finding where a leak might be coming from. Fabricating a plate takes time & material. The cost of those kits isn't all that bad when you consider what your time is worth. A single plate should fit both sides.
10-21-2018, 09:41 AM | #35 |
Another option is to take an old cylinder head and "hog out" the areas around the bores and valves - can be done, but is a lot of work. You definitely want to be able to see into the valve pockets/ports, the transfer areas, etc.. I put some soap in with the water, makes it easy to see "bubbles" in bad places! (Well - hopefully not!). Good luck
10-21-2018, 10:01 PM | #36 |
OK... Best of both worlds! A fellow barner has sent me a pm offering his speedway tester to use on my blocks. He only needed it once. I just pay the shipping. I like how it is open at the cylinders for visual inspection. And B&S, added soap is an excellent idea. We've all seen the tiny bubbles on that evasive inner tube leak.
