09-12-2013, 09:57 PM | #21 | |
Re: Adding old timey blinkers to my Ford
Headlights as blinkers. Never thought or heard of that. Good thinking. MIKE |
09-14-2013, 12:09 PM | #22 |
One of the problems with add on turn signals is their not canceling. So I added a mini buzzer in the circuit. That was great till your stuck at a traffic light. By pulling a small,piece of tape on the buzzer you can control the volume. Works for me.....
1939 Fordor Deluxe 1939 Ford Coupe Std 1940 Ford pickup Nothing in life is to be feared; it is only to be understood. |
09-15-2013, 06:58 PM | #23 |
Roffeman. Please show the drawing.
Thanks |
09-15-2013, 07:25 PM | #24 |
I tried using fog lights for front turn signals on my '35 and to be honest, they were hard to detect during the day due to the power draw through 16-18 gauge wiring. As a suggestion, I would keep the bulb size small (avoid 6" fog lights) and run a relay (with 12-14 connecting gauge wiring), to each bulb to get a brightness that can be seen.
Others may have had better luck than me but, the problem I found with using integrated parking lights or low beams for turn signals is their practicability at night with the headlights on borders on nil. Finally, as I recall, turn signal switch hardware found on '60s VW were very popular at one time for mounting column turn signals. They looked like they were factory-made for early Fords. Tom |
09-16-2013, 12:43 AM | #25 |
It's in my head, give me some time...
Rolf |
09-16-2013, 09:03 AM | #26 | |
New sockets to hold modern 1157 12v bulbs were a snug fit in the reflectors after the original sockets were removed. They are very visible as parking/signal lights. Last edited by 40cpe; 05-25-2014 at 09:20 PM. |
09-16-2013, 04:30 PM | #27 | |
09-17-2013, 12:36 AM | #28 |
40cpe-
What you are doing for front turn signals is the ideal way of doing it. When I was referring to 6 inch fog lights I should have specified the more common seal beam types. They need the heavier wiring and a relay(s) to get the full advantage of them. Especially, when using the typical add-on column turn signal switch with its' 16-18g wiring. Tom |
09-26-2013, 06:23 PM | #29 |
For what it's worth.... I used the ones made by "Ticking Thru Time". They run a hidden switch and have an audible beep so you don't leave them on. Worked great on my 37 and will use them on my 33.
