Old 11-25-2015, 03:56 PM   #1
Prawbly
Prawbly's Avatar
Send a message via AIM to Prawbly
Default valve clearance for offenhauser heads
What's the valve clearance needed between valve and head in a flathead ?
Last edited by Prawbly; 11-25-2015 at 04:23 PM. Reason: no response with original post
Prawbly is offline   Reply With Quote
Old 11-25-2015, 05:41 PM   #2
HP Hunter
Default Re: valve clearance for offenhauser heads
Lay the heads on top turn the motor over without any head gaskets. If it goes without hitting anything youll be ok when the gaskets are there. Hopefully your using an aftermarket gasket.
Harry
HP Hunter is offline   Reply With Quote
Old 11-25-2015, 08:41 PM   #3
Prawbly
Prawbly's Avatar
Harry
Thanks Harry
That'l work for me. Pat
