Old 09-24-2016, 02:51 PM   #1
1929
Default Tachometer?
Should the Model A RPM stay under 3000?
1929 is offline   Reply With Quote
Old 09-24-2016, 03:38 PM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Tachometer?
I think so and I like to limit mine to 2000.
Old 09-24-2016, 03:41 PM   #3
tbirdtbird
these are long-stroke, low-revving motors with boatloads of torque down low, you don't need to rev the nuts off it
'31 180A
tbirdtbird is offline   Reply With Quote
Old 09-24-2016, 04:14 PM   #4
Mitch//pa
I like that
Good explanation ...
Old 09-24-2016, 04:32 PM   #5
Jacksonlll
Jacksonlll's Avatar
45 mph is about 2400 rpm.
Old 09-24-2016, 06:01 PM   #6
old31
What do you guys use for a tach, and how do you hook them up
old31 is online now   Reply With Quote
Old 09-24-2016, 06:35 PM   #7
TerryH
TerryH's Avatar
Why do you need a tach on a Model A? Like everyone says, they are a low rpm engine. I cannot imagine why a tach would be useful or necessary in normal operation.
TerryH is offline   Reply With Quote
Old 09-24-2016, 06:44 PM   #8
Mitch//pa
My ears...no wiring necessary
Old 09-24-2016, 06:52 PM   #9
nick c
I bought a Bosch from Jegs, FST7906, 2 5/8" diameter, now $34.21. It mounts on the column.
nick c
nick c is offline   Reply With Quote
Old 09-24-2016, 08:00 PM   #10
mshmodela
mshmodela's Avatar
TACHS are for show. I drove manual tranny cars exclusively for the first 30 years of my driving and never used them... I looking forward for the 2018 jeep pick up and 6 speed manual --on my list.
-Mike
Late 31' Ford Model A Tudor, Miss Daisy
I don't work on cars --I'm learning about my Model A.
Cleveland, Ohio
mshmodela is offline   Reply With Quote
Old 09-24-2016, 08:13 PM   #11
1crosscut
1crosscut's Avatar
Have not hooked one up myself but I'm sure someone here will be able to explain how it is done on a Model A.
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Old 09-24-2016, 08:48 PM   #12
sphanna
sphanna's Avatar
post 5 2400 rpm is about 55 mph with 3.78 not 45
Steve Hanna, Polk City, IA
sphanna is offline   Reply With Quote
Old 09-24-2016, 08:59 PM   #13
PC/SR
I have the tach Snyders sells and it hooks up off the coil. Easy to do. As said, no need for one for most driving but that is an individual matter. Get the 0-3500 one. The A engine can handle over 3000 rpm, but again, not much need to do so in normal driving. They are tough engines.
PC/SR is offline   Reply With Quote
Old 09-24-2016, 10:21 PM   #14
CWPASADENA
CWPASADENA's Avatar
I use a "Tiny-Tach".
It is a small digital tach that will mount almost anywhere.
All it needs for a hook up is one wire that is grounded and a second wire that wraps around the coil wire.
I like to run the engine between 1750 and 2000 RPM while on the road. I limit the engine to no more than 2300 RPM for short periods of time when pulling a steep hill in the lower gears etc.
I find a tach very helpful and it is fun to watch the speed of the engine.
My opinion,
Chris W.
CWPASADENA is offline   Reply With Quote
Old 09-26-2016, 09:11 AM   #15
burner31
burner31's Avatar
nick c
I believe that JEG's tach is a 12 volt positive ground 8K...not much use on a true Model A
If I'm wrong please correct me.
I for one would like a tach, but a workable/usable one is a lot of dough
Keith
Shawnee OK
'31 SW 160-B
Old 09-26-2016, 09:15 AM   #16
burner31
burner31's Avatar
My opinion,
Chris W.
How about some info about that "tiny tach" model number, etc, etc.
Pics of the hook up and mounting would be helpful also
Keith
Shawnee OK
'31 SW 160-B
Old 09-26-2016, 10:06 AM   #17
bettlesr
bettlesr's Avatar
I don't remember where I bought these but they are VDO gauges. I have a full pressurized engine to go with the oil pressure gauge.I believe the tach is 12v neg ground. It can be set for 4, 6 or 8 cylinders. I think I got them from Summit Racing.
1965 Lotus Elan S2
1930 Model A Sport Coupe
bettlesr is offline   Reply With Quote
Old 09-26-2016, 11:21 AM   #18
Panteren
Panteren's Avatar
http://www.snydersantiqueauto.com/tachometers
Panteren is offline   Reply With Quote
Old 09-26-2016, 11:49 AM   #19
CarlG
CarlG's Avatar
Here's mine:
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 09-26-2016, 02:40 PM   #20
wensum
wensum's Avatar
I have a Tiny Tach mounted in my car and it's small and easily mounted.
The response to revs is a bit delayed, but it does show you what revs you are doing and has an hour meter as well. As I recall they are cheap too!https://www.tinytach.com/
Keith
wensum is offline   Reply With Quote
