09-14-2016, 10:07 AM | #21 | |
Re: Trying to remove water pump-HELP!
09-17-2016, 04:11 PM | #22 |
Ok, just got my new "Leakless" water pump from Snyder's. Everything seems to fit well. Fan/pulley turn on pump without any binding on casting. I ground just a little of the rear of the shaft. I decided to stay with the original water pump mounting studs. Should I put a little blue Locktite on the threads of the studs? It didn't appear there was any when I removed the pump. Thanks again to everyone for all your help.
09-17-2016, 04:26 PM | #23 |
Smit
R/s / passenger side upper stud needs rtv or liquid Teflon The hole goes into the water jacket... The other three are blind holes and really don't need anything |
09-17-2016, 05:30 PM | #24 | |
I never took the studs out. I was referring to putting the Locktite on the studs before I tighten down the nuts & lockwashers. |
09-17-2016, 06:02 PM | #25 |
