Old 03-29-2019, 01:47 PM   #1
The Lucky Star
Default 8BA Rods in a '41 Merc Block
Hi all,
My '41 Merc block cleaned at .030. I have a set of 8BA rods that I would like to use with a 4" Merc crank. Does this sound like it will work?
Thanks!
The Lucky Star is offline   Reply With Quote
Old 03-29-2019, 02:43 PM   #2
42merc
42merc's Avatar
Default Re: 8BA Rods in a '41 Merc Block
That is the combo that works - go for it.
42merc is offline   Reply With Quote
Old 03-29-2019, 04:15 PM   #3
The Lucky Star
Great! I didn't know if the extra stroke on the crank would cause the connecting rod studs to hit the case.
Old 03-29-2019, 05:59 PM   #4
Ol' Ron
Ol' Ron's Avatar
The Merc pistons have the wrist pins higher in the piston to make up for the stroke. What pistons are you using??
The original pistons will not work
Old 03-29-2019, 06:43 PM   #5
The Lucky Star
I'm actually shopping for some .030 Merc. pistons. I have a set of Fords and like you say, they will not work.
Old 03-29-2019, 10:24 PM   #6
Ol' Ron
Ol' Ron's Avatar
That's a 99A block and we used them at Danbury bored to 3 5/16. You can get some nice 3 ring pistons from Egge.
Old 03-31-2019, 04:28 AM   #7
Mac VP
Mac VP's Avatar
Egge’s pistons for the 49-53 Mercury crankshafts are their L-991 which are 4 ring types.....these are what we stock under the Ford EAC-6108 part number. I’d have to check with Egge to see if they make them in a 3 ring version. The factory original pistons were 4 ring.
VANPELT SALES LLC
Cincinnati, Ohio
Office: 513-724-9486
www.vanpeltsales.com
www.classictransmission.com
Mac VP is offline   Reply With Quote
Old 03-31-2019, 12:11 PM   #8
40cpe
40cpe's Avatar
I have Egge 3 ring pistons in my engine with a 4" stroke. I wish I had known about the metric rings when I built mine.
40cpe is online now   Reply With Quote
Old 03-31-2019, 05:04 PM   #9
Ol' Ron
Ol' Ron's Avatar
I don't think the metric rings are available in the Egge 3 ring pistons, However they may be available in the 3 5/16 .020 and 030 pistons, FYI I've been using the Egge 3 ring pistons since the Late 80's in fact there is a pic of one in my book. (92)
Old 03-31-2019, 10:05 PM   #10
The Lucky Star
Great. I'll give Egge a call tomorrow. Is there a source for 99A head gaskets or should I just use a general 59A gasket?
Old 03-31-2019, 11:51 PM   #11
40 Deluxe
It's OK to run a 4 ring piston with 3 rings. Just leave that superfluous bottom groove empty. That lower oil ring is not needed with modern three piece oil rings.
Old 04-01-2019, 08:08 AM   #12
tubman
tubman's Avatar
I can confirm this. I left the bottom rings off the last engine I did and it runs just fine. I did, however, have the entire assembly balanced to account for the lighter piston assemblies.
Old 04-01-2019, 08:11 AM   #13
JSeery
JSeery's Avatar
You may need one of the large bore head gaskets.
Old 05-06-2019, 07:45 PM   #14
The Lucky Star
So, I'm working on the Merc. crank and I need the plugs for the throws. They are 5/8's. Can anyone recommend a source?
Thanks!
Old 05-06-2019, 08:33 PM   #15
Fordestes
Check with Falcon Global for your gaskets they handle Best gaskets, They offer GraphTite and copper head gaskets . They may have the plugs too ,I drill and plug mine.
Fordestes is offline   Reply With Quote
Old 05-06-2019, 08:58 PM   #16
leon bee
Thanks!
Dorman 555-010. With that number you can find em easy, I got some from Rock.
leon bee is offline   Reply With Quote
Old 05-07-2019, 08:46 AM   #17
Tim Ayers
Egge does not offer metric ring packs. Ross or Wisco do. Others may as well, but I only called those three.
