04-16-2019, 12:38 PM | #1 |
Compression Checks
I've a '31 Pickup bought from a local Club-Member two years ago. Doing a compression check and found this: Number 1 & 3 read 60 PSI with numbers 2 & 4 are 59.
My original concern was the number 2, as it shows an oilie residue/a build up on the bottom of the plug when I have them all out for cleaning/resetting. My plugs are Autolite 3076. I have no issues with the way the engine performs. Is anything going on here? Thanks Guys |
04-16-2019, 01:01 PM | #2 |
Re: Compression Checks
Sounds fine to me. I like Autolites, 3076 are a tad cool but 3077 [which I prefer] are hard to find nowadays.
04-16-2019, 04:46 PM | #3 |
You could have worn valve guides in that cylinder which is allowing a little oil in. That condition wouldn't show up on a compression check.
All steel from pedal to wheel |
04-16-2019, 06:28 PM | #4 |
04-16-2019, 08:53 PM | #5 |
Or, the oil control ring in that cylinder is damaged and letting oil by, while the compression rings are still good.
04-16-2019, 09:53 PM | #6 |
04-17-2019, 08:28 AM | #7 |
Why the hell are you diddling with a car that runs FINE?????? You'll wear out the bolt THREADS!!!
Bill W.
04-17-2019, 08:51 AM | #8 |
Thread Tools | |
Display Modes | |
