01-12-2019, 07:50 AM | #1 |
problem with coil
hello guys
i had a problem with my coil , she burned with the wiring ,from the coil, to the ignition cap distributor does anyone knows where the problem come from? |
01-12-2019, 12:09 PM | #2 |
Re: problem with coil
i post the pics
01-12-2019, 12:45 PM | #3 |
I had one do that also. Never did figure out what happened. I replaced the coil and wires involved and it was still ok when I sold the car. Coils can be strange beasts!!
01-12-2019, 02:27 PM | #4 |
What I am thinking (scary) is high secondary IGN resistance , either plug wires and/or plugs. Maybe need to perform a resistance test on the wires. What type of plug are you running? Points or PERTRONIX?
And then again it might just be a CHINESEIUM parts failure.
DIAGNOSED CDO - (OCD In Correct Alphabetical Order) |
01-12-2019, 05:51 PM | #5 |
I had that happen on my truck with a Duraspark II. Did it once so I don't know but it was with a set of 9mm Ford Racing plug wires and motorcraft copper plugs. I always wondered if it was just a defective coil wire.
'56 Ford Fairlane Town Sedan - 292 Y8 - Ford-O-Matic '78 Mercury Cougar XR7 - 351W - FMX '82 Ford F150 Flairside - 302 - C6 |
01-12-2019, 06:05 PM | #6 |
. Last edited by dmsfrr; 01-12-2019 at 10:14 PM. |
01-12-2019, 06:07 PM | #7 | |
Could have been a coil wire, cap or rotor and wires/plugs.
01-12-2019, 06:14 PM | #8 |
Possible, but I changed just the wire out and it never did it again.
Wont be a problem for me when I put my new engine in, I got a new dist for the truck with a steel gear for a roller cam and I have a new NOS cap, cap adapter, and a motorcraft rotor to go on the new engine. I just thought it odd that it just did it with no sign. It didn't burn it two on mine it just when I pulled the coil wire off it actually fell apart and was no good then. Think I was pulling the wire off to pull the coil to have a easier time pulling the valve cover.
01-13-2019, 06:35 AM | #9 |
thanks for the answers ,i changed by the new one and now it start and runs good, maybe i'll must to change the points and the condenser?
01-13-2019, 08:09 AM | #10 |
even with the burned coil the car to restart but there were small sparks + or - terminals, is it strange?
01-13-2019, 12:26 PM | #11 | |
You need a new coil, and all new spark plug wires, if the condition of the coil wire is any indication. . Last edited by dmsfrr; 01-13-2019 at 05:50 PM. |
