07-30-2012, 11:01 AM | #1 |
Air cleaners
Which of these air cleaners is the correct one for 1937 Ford pickup?
07-30-2012, 11:24 AM | #2 |
Re: Air cleaners
37fordpickup ......................
The bigger air-cleaner was an accessory for driving in dusty road conditions. It was an oil-bath cleaner. MIKE |
07-30-2012, 12:39 PM | #3 |
Re: Air cleaners
Mike is correct in Post #2. The other one looks close to one of the styles available in 1937 but you should get a copy of the Restoration Guidelines from the Early Ford V8 Club and decide for yourself. You might post a few other views. There were a couple of styles available.
Charlie Stephens |
07-30-2012, 03:10 PM | #4 |
Re: Air cleaners
My memory tells me that the gray filter was on the 37 when i got it many years a go. The smaller black one was off a 39 panel which had a 24 stud FH. The big one is gray because it was just sandblasted and painted primer gray for now. Both are oil bath air cleaners.
07-30-2012, 03:10 PM | #5 |
Re: Air cleaners
Picture #1 above is what's known as a 'hat type' oil bath air cleaner made by either United Air Cleaner Co. or Donaldson Co., Inc. These are both considered accessory air cleaners for passenger cars and probably light commercial vehicles.
Picture #2 above is a heavy duty oil bath air cleaner also made by United Air Cleaner Co. It was more commonly used for trucks than for cars but was sometimes installed on cars in especially dusty conditions. The '37 (also '38 & '39) passenger car and probably light commercial vehicles normally used an oil wetted air cleaner, made by AC and others, which could be taken apart so the element could be cleaned and wetted. See pictures attached below:
07-30-2012, 03:12 PM | #6 |
Re: Air cleaners
You did not ask, but for what it is worth, the intake manifold on the engine is not a '37 manifold, which has a low profile to the generator mount unlike the one in the photo. |
07-30-2012, 04:26 PM | #7 |
Re: Air cleaners
John, I disagree. The #1 picture is neither the Donaldson nor the United hat type oil bath cleaner (Notice the incorrect step down at the halfway point in the body of the filter).
Picture #2 appears to be of a 79-9625, made by United, which is correct for 1937 and beyond (with a minor mounting bracket change for '39), as optional equipment for extreme dust conditions. David, it does appear that the engine shown sports bolt-ons from several different years, as of course the block itself is incorrect for 1937.
Alan |
07-30-2012, 06:11 PM | #8 | |
Re: Air cleaners
"Never complain,never explain"... Henry Ford II |
07-30-2012, 07:11 PM | #9 | |
Re: Air cleaners
07-30-2012, 07:15 PM | #10 | |
Re: Air cleaners
07-30-2012, 07:17 PM | #11 |
Re: Air cleaners
Alan,
Oops! I did not count the studs; shame on me. Dave |
07-30-2012, 07:20 PM | #12 |
Re: Air cleaners
John, Morning coffee yes, but I prefer ice tea in the afternoon (Long island, that is).
Alan |
07-30-2012, 07:37 PM | #13 |
Re: Air cleaners
I really appreciate all the pointers and if this restoration was going to be a show car, I would be making some changes. I dismantled the 21 stud and the 24 stud motor over 20 years ago then put all the parts and pieces away. The 21 stud from the 1937 has a bad cylinder which probably can't be sleeved. The 24 stud I removed from a 1939 Panel and has been rebuilt. I went out to the garage and pulled out the other intake and David is right. The generator mounting is at least a half inch lower. I have a Stromberg 94 and a 2 97's. A 97 is in the pictures and the intake and base match up. What do I need to be looking for as far as fuel pumps? What is in the picture needs rebuilt or tossed on the spare parts pile.
07-30-2012, 08:15 PM | #14 |
Re: Air cleaners
With the generator sitting higher on that later intake, and the fan mounted to the generator pulley, the fan blades may hit the bottom of the radiator tank. Is the '37 intake still usable? You may need to switch back. Sometimes when we mix and match engines/parts/etc., it takes some time to get everything to fit/work properly again. If you are not building a show vehicle you don't need to worry about everything being totally correct as built by Henry. Which transmission are you using? From what I can see in those pictures, it looks like it may be the four speed with a granny gear/stump puller low. Nothing wrong with that if you are building a work truck. If you are building a driver, the smaller three speed may work better for you. IMO
07-30-2012, 08:15 PM | #15 |
Re: Air cleaners
Theres no way your going to make that 24 stud engine look like a 37 21 stud no matter what you change. 37 fuel pump is a pretty rare item [all metal pump with offset inlet and outlet holes] The motors wrong for the car so make the best of it. OMO ken ct.
07-31-2012, 05:09 PM | #16 |
Re: Air cleaners
The smaller one on the left is the same one that came with my orignal 37 pickup.
07-31-2012, 09:49 PM | #17 | |
Re: Air cleaners
That filter was not original to any '37 Ford.
Alan |
