06-04-2017, 04:19 PM | #21 |
Re: Shutting my Roadster off.
Back in 1966 I was working at a freezing works and using my 1929 Phaeton for daily transport. It had no ignition key and just a simple on/off switch, consequently I always turned the petrol off.
Workers at freezing works tended to be rugged characters and inevitably I finished work one day to find my car gone. The works were down a very long drive, and after reporting it stolen to the police, I found it at the end of the drive with a flat battery. The thief had got only as far as a bowl of petrol and then flattened the battery trying to restart it. Keith |
06-04-2017, 05:58 PM | #22 | |
06-04-2017, 06:04 PM | #23 |
You are the one doing the right thing. Fuels these days are a mix of many hydrocarbons with varying boiling points. In your situation over there, ethanol as well. The more volatile ones evaporate quickly, especially in the warm environment of the engine. Only the thick, heavy hydrocarbons are left. When you come to restart it, those heavy hydrocarbons don't atomise/vaporise nearly as well as the more volatile ones so starting is more difficult.
Keep doing what you are now.
06-04-2017, 06:22 PM | #24 |
Here is how I look at it:
I turn off gas valve when I am away from the car has worked since 1962. When I stored car over winter in a garage with a heater / water heater or without for that matter... (A Pilot light and or Burner will ignite any spilled gas). remove the gas line from carb, loosen the gas line at sediment bowl. turn gas line up 180 degrees so that outlet is ABOVE the level of gas in tank. Tighten fitting on sediment bowl gas line. That way there will be no leaks from carb and if someone turns the gas valve on while you are gone there will be no leaks. OR remove both ends of fuel line make a 4 inch fuel line with the end crimped and soldered shut. Install this line in sediment bowl fitting to prevent any leaks while in storage. Or empty gas tank. Last edited by Benson; 07-01-2017 at 07:19 PM. Reason: additional info added blue text .... |
06-04-2017, 06:23 PM | #25 |
06-04-2017, 06:24 PM | #26 |
Model A Ford Club of New Jersey http://www.mafcnj.org Model A Pick Up Owners and Enthusiasts https://www.fordbarn.com/forum/group.php?groupid=5 |
06-04-2017, 06:32 PM | #27 | |
06-04-2017, 09:12 PM | #28 |
i turn off the battery disconnect then the fuel , let the car run out of gas then everything is dead! i have a up draft and the fuel will get into the motor if i don,t shut it off
__________________Brenden in post 11 I don't understand. How does it run out of fuel when the battery disconnect is off. No power, no ignition! Must be in the reverse order...disconnect after the carb runs out of fuel. |
06-04-2017, 10:34 PM | #29 |
Its the factorys scattered all across the states above the 42nd parallel that gets turned on every nov/december to create winter!
Google says its a New Zeland term for a meat packing plant but ill let you choose
06-04-2017, 11:28 PM | #30 | |
06-04-2017, 11:41 PM | #31 | |
06-04-2017, 11:45 PM | #32 | |
1) Friendly, mean well people that just want to start a conversation and don't know how to start it. 2) Know it alls that just have to tell others what to do. Either case when I'm told such things I answer with a smile "Thanks, I did not know that".
06-05-2017, 02:28 AM | #33 |
A place where animals are slaughtered and processed into meat. In New Zealand we grow great grass and hence great meat. Because we are so far away from most of our markets our meat has traditionally (for the last 150 years) been exported frozen -Hence Freezing works . Try some New Zealand lamb you won't be disappointed! -Karl |
06-05-2017, 06:14 AM | #34 |
Trying to buy lamb in the US is like looking for the winning lottery ticket. If it isn't beef, it isn't meat over there! We finally found some but it wasn't like the stuff we get at home.
06-05-2017, 08:35 AM | #35 |
I have run into 'experts' at car shows and such, I just let them wind down and move on. There is someone who always knows just a bit more than you do. I listen and then check their street creds later. Your sequence in shutting down is the best way in my opinion. No 'engine harm' can come out of that.
1928 Niagara Blue Phaeton 1972 Olds 442 Convertible 1979 MGB -Life's Too Short To Drive Boring Cars- |
06-05-2017, 05:57 PM | #36 |
A car with gravity feed fuel is a car with a perpetually running fuel pump. Henry didn't add parts just "for the heck of it," we know that.
And to add: I always run carbs dry, works great. |
06-06-2017, 12:00 AM | #37 |
06-06-2017, 12:51 AM | #38 |
I'll have some Oregon lamb! Got some in the freezer.
I know the voices aren't real but damn they have some good ideas! |
06-06-2017, 02:24 AM | #39 |
My garage is integral so the carb is run dry and my kill switch is engaged every time. Bigger picture!
Kevin Flood West Berkshire UK Member MAFCGB, VHRA, SAH, Brooklands Trust Sporadic progress on My 1929 Sport Coupe can be found here along with my blog http://automotiveamerican.com/ |
06-06-2017, 02:58 AM | #40 |
I switch off the fuel and the battery kill switch every time I leave my car for more than a few minutes. It's just a routine that I've got into. I've never drained (run) the fuel out of the carburettor and have never experienced any problems from not doing so. My routine on my boat is different, there when I've returned to the marina part of my routine is to disconnect the fuel line and wait for the motor to stop. Thinking about it I probably do it for a couple of reasons:
1. I might not be using it for a few weeks. 2. I used to have two stroke outboards and with them there can be real advantages of leaving the carburettor dry. Running the car until it stops from fuel starvation may not be necessary but it certainly won't do any harm. |
